weve got a position opening to work for our plastering team Northside plastering (small team of only 7 peaple).
we need a new labourer, must have own transport, steel cap booties.
its hard work, good hours. and good money, and if u like it u can stay on and learn the trade $$$
its not suitable for uni student who want part time work, this is full time
u dnt need to give any resumes just give me a call or pm or txt.
cheers guys
simon
0422406453
https://www.sau.com.au/forums/topic/153300-job-offer/
PM me or post up some more details, (hours/ times) and what is the pay per year before tax.
I have a mate very interested and I could even consider it.. need a change and this might be the way 2 go..
(is this a fixed term contract or an ongoing employment)
Cheers!
- Adam
https://www.sau.com.au/forums/topic/153300-job-offer/#findComment-2871843
atm we (should!!) be finishing a house in success tomorrow
in the new magnolia gardens estate (or something like that)
then we go to coogee if i remeber rightly
Tomorrow is a poets day - yipee!!!
piss off early, tomorrows saturday, or in this case, piss off early, todays a stinker
Edited by 342Four
https://www.sau.com.au/forums/topic/153300-job-offer/#findComment-2872056
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
