200sx S15 Bilstein, Whiteline, Eibach & Noltec Suspension
I have just finished the engineering for Jamex on the 200SX S15 Bilstein and Whiteline Suspension kits. These have been extensively road and track tested over the last 4 months in three S15’s. Similar to what I did for R32/33/34’s, they will be offered on a Group Buy from Jamex for 15% to 20% less than the recommended retail prices, plus freight will be free for all orders over $500, plus there will be an additional discount of 5% for orders over $1,000.
The Group Buy kit was engineered (by me) to give a sporty, but not harsh ride, for the street and at the same time suite the sort of things that S15’s owners use their cars for (road, drag and circuit). It’s a great all round kit judging by the comments back from the people that have tried it.
Due to the strut based front end there will be a basic kit with Whiteline coil springs. Plus a full height adjustable coil over kit utilising Eibach (the best) coil springs with Noltec adjustable strut tops as an option. Extensive engineering has been carried out on a full replacement coil over front strut which features a unique Bilstein shock absorber. Plus it allows greater scope for camber adjustment combined with the use of wide wheels and tyres.
Front Bilstein inserts and rear shocks
Front fabricated strut with the Bilstein insert
Rear Bilstein shock with Whiteline spring
Picture of Bilstein/Eibach rear coil over spring/shock unit
Picture of the Noltec adjustable strut top
Rear Camber Kit
Front Caster Kit
In all cases the Bilstein damper valving has been selected (by me) to suite the spring and stabiliser bar rates used. I have spent some time engineering in an additional 20 mm (23 mm at the wheel) front suspension travel to avoid one of the major limitations of the packaging in an S15. This means I could use a lower spring rate for better handling and ride and, at the same time avoid the bottoming out issues that frequent lowered S15's The Bisltein front struts incorporate an internal bump stop which has been rated and sized to suite the rest of the kit. For better control of dynamic camber and caster, the Bilstein front inserts feature the inverted layout which results in far stronger resistence to the bending forces that struts have to endure.
The rear Bilsteins are of course full shock replacements and the Whiteline Bump Stop & Dust Cover kit has suggested trimming heights as follows;
There is a full set of suggested alignment settings (including ride heights) for both road and track use, which are designed to optimise the handling and avoid excessive tyre wear.
Table of alignment settings
Recommended Road Settings
Front
Caster = 7 degrees positive (slightly more on the LHS to counter the drift to the gutter)
Camber = 1.25 to 1.5 degrees negative
Toe = Zero
Rear
Camber = 0.75 to 1.25 degrees negative
Toe = In 2 mm each side
Recommended Circuit (grip) Settings
Front
Caster = 8 to 9 degrees positive
Camber = 2.5 to 4.0 degrees negative
Toe = Zero
Rear
Camber = 1.25 to 2.0 degrees negative
Toe = Zero
Recommended Drift Settings
Front
Toe = Zero to 1 mm toe out each side
Rear
Camber = 0.75 to 1.0 degrees negative
Toe = Out 2 mm each side
Recommended Drag Settings
Front
Toe = Zero
Rear
Camber = 0.25 positive to zero degrees (never negative)
Toe = Zero
Price Lists
The Road Kit is designed for daily sporty driving and is suitable for occasional circuit, drag and drift work. Although an upgrade to adjustable stabiliser bars would be recommended for those willing to tune the handling for their personal preferences.
The price lists reflect a saving for SAU Group Buyers of $678 (around 25%) over normal retail prices.
The Road & Track Kit is suitable for road driving, to and from the track and other weekend work. Several of the guys during the testing have commented that they could easily live with the Competition Kit as a daily driver. The stabiliser bars are, of course, adjustable, plus the springs and damper rates are not in any way excessive. The recommended alignment settings are a bt extreme for daily driving and would result in excessive tyre wear if large numbers of kilometres are driven. The Road & Track Kit is priced the same for Drag, Circuit (grip) and Drift users. The spring, shock and stabiliser bar rates being the difference. So please specify your usage patterns when ordering.
The price lists reflect a saving for SAU Group Buyers of $1,215 (around 25%) over normal retail prices.
Availability
Springs are usually in stock at Whiteline and Eibach
Bilstein takes 1-2 working days to fit the inserts
Bushes are usually in stock at Whiteline
Stabiliser bars take 4-5 working days to make as Whiteline do not keep stock
Delivery is via Toll priority and usually takes 1-2 working days to anywhere in Australia.
Recommended Fitting Workshops
Heasmans Sydenham NSW
East Coast Suspension Kirrawee NSW
St George Steering Punchbowl NSW
Exceller Steering Bankstown NSW
Centeline Thomastown Vic
Traction Tyre & Suspension Rowville Vic
Manta Racing Services SA
Discount Tyres Service Belconnen Act
Motsons Qld
Wilkinson Suspension WA
As per the Skyines Group Buy, you can choose individual parts or groups of parts, just keep in mind the free freight for orders over $500 and the extra 5% discount for orders over $1,000.
Any questions? Send me a PM or post it here.
:yes: cheers :rolleyes:
PS; The S14 Group buy kits are now open, for S13 (CA & SR) owners, their kits are currently being engineered and will be released shortly
  • Replies 148
Posted Images
Ah damn SK. I wish I knew you were going to develop something for the Silvia chassis! Bah splurged a heap of cash on some Zeal coilovers only a few months ago (mainly to address the issue of lack of front suspension travel). What spring rates have you decided to go with?
PS If you have this going on ns.com it would be hot cakes... if you need assistance I'll be happy to as I am a sponsor mod.
I too am interested in this setup, as I'd rather a well setup coil and shock than all the fancy height/damper/rebound/kite flying stuff that some other designs have. I'll only want to set the height once, then leave it at that.
I've got this thread to remind me when someone replies so I can monitor it, I look forward to seeing prices etc for the S14's!!
Cheers,
Theo
Just waiting on the last of the prices to come through. They will be in the designated place in the #1 post.
:blink: cheers :P
Dude just in time was about to order some HKS Performers! How do you think ur package will compare with these (6/4 rates) on a hard driven street car with an occasional track day?
Based on the results of the guys currently using it, the kit will piss all over any Jap suspension. Road or track. Ask around and you will find that I don't exagerate.
:( cheers :laugh:
drift?
i also have the same question with a bit more detail behind it.
i have a s13, which i use as my daily but also drift on track. would the s13 setup be adequate for drifting ? or is it to soft/ more street based? any idea on the spring rate?
id much prefer to buy a set of these over hsd etc.
thanks
Yes, there will be a kit specifically engineered for drift. It will feature larger adjustable stabilsier bars, which means you won't have to put up with excessive oversteer when not drifting.
Yes, there will be specific recommended drfit alignment settings.
:) cheers :(
:happy: cheers :D
i already got a set of adjustable swaybars, but id defenitly be keen on a set of shocks/springs for a s13, the sooner the better as my shagged coilovers are in desperate need of replacment.
PS If you have this going on ns.com it would be hot cakes... if you need assistance I'll be happy to as I am a sponsor mod. [/size]
^ I can confirm the interest!
I just heard about this on ns.com and am very interested, pending pricing.
    • Yeah nice idea, you mean to suction it to the gauges? I hadn't thought of that.
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
