200sx S15 Bilstein, Whiteline, Eibach & Noltec Suspension
Just a quick question! How come the kit doesn't include a rear strut brace?
Regards,
Albert
Hi Albert, the rear strut braces are pretty inneffectual as the rear upper control arms and traction rods attach to the subframe, not to the chassis. Front strut braces are a good idea as the front upper control arms attach to the chassis, hence a strut brace heps to retain the wheel alignment settings. I have only included items in the kit that I consider necessary.
You can fit a rear strut brace once you have done everything else, but it's not good value for money.
:( cheers :D
  • Replies 148
Posted Images
I've sorta found some strut tops.. so hopefully i'll be buying the road kit soon... just one quick question though, what is the height like? I mean, i'm assuming it's not adjustable at all, so how will it sit in terms of height compared to a stock suspension with the whiteline springs?
Ride height is around 30 mm lower than standard. You can get another 15 mm with the low profile front strut top. Then use the extra circlip grooves on the rear Bilsteins to lower the rear a similar amount. That's about as low as you want to go for good handling and ride comfort.
:( cheers :D
Hi guys, my inbox is filling up faster than I can respond to the PM’s. I usually get 30 to 40 PM’s a day. With the current delay in delivery, that has increased to 40 to 50 per day and I just can’t keep up with that sort of volume. Particularly as some of the more technical PM’s take 10 to 15 minutes each to reply to and my available time has decreased dramatically for reasons which will become obvious shortly.
I feel that I need to “broadcast” a Group Buy update until I can clear the backlog of PM’s. Here is the current situation;
1. A little back ground first. As you may be aware Redranger and Whiteline merged a couple of months ago. The first step was a merger of Sales, Marketing and Distribution functions and Whiteline’s Minto premises were simply not large enough to accommodate this. So the premises adjacent to Redranger at Somersby were acquired and that was utilised for the larger, merged entity. Some people have taken this as a sign that Redranger “took over” Whiteline, when that is in fact not the case, it is a true merger.
The Whiteline manufacturing premises at Minto remain. More news on that shortly.
2. How this affects the Group Buys. Many of the products that I specified for the Group Buy Kits are unique, it is what makes the kits “work” better than any other Skyline suspension update. This uniqueness has been possible because of my knowledge of the systems within Whiteline (plus Bilstein, of course). The Redranger merger has disrupted that system and the “unique” (to the Group Buy) parts have not been flowing through as they had previously.
3. The good news. I have been working 14 hours a day, every day, for the last week, including yesterday (Saturday) helping to clear that backlog of orders. As a result, all of the Group Buy orders should be delivered this week. At this point I can’t tell you what day your individual order will be delivered. But as they flow through the system I will inform you of the con note numbers as soon as they are issued (the normal system).
In conclusion, I know you probably don’t care about the reasons, you just want your stuff and that is totally understandable. But I felt I had to give some background and let you know that I am working on clearing the backlog (personally as it happens) so that we can return to our previous prompt responses. Please hang off on the PM’s, I promise you that I haven’t skipped off to Brazil with your money. That your stuff will be delivered very shortly.
:) Cheers :(
Thank you Gary~ :)
Anyway, I just realised that since I'm going for the eibach/bilstein coilovers, how did the whiteline cause the delay? Which part of this coilover is made from Whiteline parts?
Edited by eron
Thank you Gary~ :)
The rear bump stops :) your kit will be shipped Monday (tomorrow), I will let you know the con note number then.
:( cheers :)
so what does this mean to the s13 kit? The prices for it haven't been released either =/ thanks Gary
Delayed a little, I have been too busy to chase up prices from the recalcitrant supplier.
:D cheers :D
very interested....
do these come with a warrnty if so how long and whats the procedure?
say when the time comes to get new shocks can our local bilstein supplier refit new shocks at the right valve rates or do we need to send it back to u etc?
finally is there sitll a bottle neck with whiteline or has that all been sorted out?
-Peak
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
