200sx S15 Bilstein, Whiteline, Eibach & Noltec Suspension
  • Replies 148
Posted Images
^ will this be addressed in future kits?
Nope, we haven't found that the brackets are necessary on the Road and Track kit, as most guys doing track work have changed to braided hoses all the way to the calliper. The brackets are there on the Road Kit of course.
:D cheers :D
A few comments;
Coil overs can't fix suspension geometry problems when you lower a 200SX too far. Hence it doesn't matter what brand of coil over over you use, anything below the recomended heights will most certainly result in geometry issues. Stick to a sensible height and you will have a great handling vehicle with good ride comfort.
The "metallic noise" previously mentioned was a loose sub woofer crashing around in the boot and the spare wheel well, which had no spare wheel in it.
The bump stops are 80 mm when untrimmed. The trimming ratio is not 1 to 1, we need to have more bump stop available to absorb the impact the lower the chassis is. Otherwise there is potential for the shock to bottom out. The theory (of 1 to 1) means that 80 mm lowering = zero bump stop, which is pretty silly. Obviously we use a ratio for bump stop trimming that is less than 1 to 1.
I have spoken to Chris at Centreline and he is happy that there are no issues with the kit as supplied.
:D cheers :D
Well, not exactly. My rear is 355mm now and there's still a pretty loud metallic noise when going over hard/high bumps.
Then for the fronts, which is 355mm at the moment, occasionally, I get a little creaking when steering is under stress. Or when going over undulated road surfaces.
Other than that, at the ride height, it's fantastic! :D
Edited by eron
Other than that, at the ride height, it's fantastic! :sick:
Have you taken it back to Chris to check? Last time he spoke to me, he said it was OK.
:dry: cheers :sick:
+1 to Gary aka Sydneykid he has been very helpful throughout the whole process was a slightly longer wait then expected but deffinately worth it car feels amazing. Haven't had a good chance to try it out at its limit but definitely very happy with this product.
Thanks for all your understanding and help Gary!
-Peak
it's already done.
read my review if you want.
Gary if you believe i'm too critical please ask me to revise it. I honestly appreciated your work.
http://www.nissansilvia.com/forums/index.p...60#entry3427886
Sorry for the delay in responding, especially to PM's. The video card in my home PC died and it took me 4 days to find out what it was and fix it. So I am about 110 PM's behind at the moment and trying hard to catch up. Add that to the workload at Superior Suspension (12 to 14 hours a day, 6 days a week) and it will take me a few days to answer everyone.
Hang in there, if you have transferred money, it's safe, I am not going to run off to Brazil with it. You won't miiss out, the Group Buy isn't going to end soon as I have spent some time with Bilstein securing the shock supply for a couple of months at least.
Advanced warning, I am off to the US for 5 weeks from 1st October to 5th November. Checking out some east coast action, Detroit, Chicago, Daytona and the SEMA show in Vegas. So when I don't respond to PM's or emails in that period, I am sure you will understand why.
>_< cheers :D
    • As I wait for parts to be delivered, I have managed to procure via a contact a R32 Nistune ECU......for now I just want to monitor what the car is doing but eventually.......who knows where we go 😂
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
    • Good old Orange Park hey... 😛   f**k I miss that race track
    • lo, it was a death trap. Good times. Got any Fatz Drift Day DVDs still available?
    • Yes, overthinking. Many PS reserviors are completely opaque. Our Skyline ones, for example. Have to remove lid, peak inside, swirl the dipstick, try to remember how to read it, etc etc. Normal. Radiator overflows are often sufficiently opaque and scunged up that you can't see the true level inside anyway, and have to open and have a peak. Besides which, I replaced the (massively expensive, even back then) plastic overflow in my Alfa GTV, back in the '90s with a stainless one that I had a good fabricator make up to be dimensionally same-same, that looks remarkably similar to the Bogan's Moroso one above, and I never suffered any particular paranoia that I didn't know how much coolant was in it.
