Not confused...that is the line I am referring to.
I think in his original question he may have been referring to the oil return gallery on the drivers side front of the head where the NVCS oil feed is usually situated.
The oil return on the passenger side can be run back to the turbo return...yes, but not necessary if you have extra oil returns on the back and restrictors in the feed galleries.
for a road car that is probably correct, for anything track related you need em all, even with back return and restrictors.
Either way an extra oil return required or not can only be beneficial. But obviously as always these things depend on application and setup.
i will have oil feed restrictors. I heard they are essential to stop all the oil running to the head and leaving the sump dry. Thanks for your help guys. its still all a little blurry to me atm but my engine isnt yet ready to go back together im simply asking due to comments ive heard from others. I'm sure once im putting the two engines together i'll be able to relate what your saying to whats infront of me.
So let me get this straight,
1. there is no oil supply for the 25 head VVT on the 30 block but you can supply it externally by drilling and tapping a fitting into the oil gallery for the VVT on the head?
2. There is a water jacket that needs sealing on the 25 head?
1. correct.
2. no water jacket that needs sealing up completely, if thats what is meant. If there is, we havent done it on either of the two 25/30 weve built for our race car. There is the waterjacket which doesnt have much sealing area for the headgasket, so we built that up with weld to match the headgasket. However alot of people get away with doing nothing for that one.
3. there is no front head oil return fitting in the rb30 block, just the turbo oil return. You can either block that off like Dan suggests, 'T' it into the turbos oil return, not the greatest way or weld a fitting to the sump somewhere for it.
1. Allright!
2. "There is the waterjacket which doesnt have much sealing area for the headgasket"
So this is an area of concern that requires attention, as I would want a good sealing surface on the head gasket esp. I take it the edge doesnt match the edge of the gasket? ie is behind that line with extra gasket.
3."there is no front head oil return fitting in the rb30 block'
Is it possible to drill and tap in the same place as the 25 block?
2. from memory the gasket protrudes into the water jacket so you build up that section of the jacket so it seals on it better.
3. it could be, but the webbing and block design is different to that of the rb25, we looked at doing that but it was going to be going straight through a web i think. From what dan is saying if your running the correct restrictors and rear head return, that you can block off that front one and not worry about it.
Edited by r33_racer
Oil pressure sender feed. 'T' piece into that feed and run your line upto the fitting welded off the gallery, or if your running the std rb25 heat exchanger then you can run ops off that and your vct feed off the block.
These should help. In the first motor we used the heat exchanger and ran std ops, mech gauge off that and vct off the block. New motor has std ops, vct and mech gauge all off a 'T' piece off block.
hey i just had a thought. If i'm building an engine from scratch would it be worth buying an rb26 head and bolting that on instead of the rb25 head? That way i would have as good of an engine as any gtr just rwd. Is it worth the money and does anyone what you need and how much it costs to make it fit?
going off that thread it sound like the rb26 stock head is better because you dont have to do anything to it. but what do you need to make it fit on the rb30 block and where can u buy everything you need
theres a fair few bits of fiddley sh!t that needs doing. everythings posted in the R33 RB30 thread in the forced induction area, so instead of posting repetative questions in here, maybe go have a squizz in the other thread.
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
