Found fluid on my left hand side foot rest block in my r32 gtst. got a torch and had a look under the dash to see what it was. the fluid appears to be coming thru the firewall from the clutch fluid master cylinder, running along the push rod and then leaking down the interior side of the firewall down to the carpet.
vehicle is fitted with a twin-plate clutch and pedal is rock hard to push down, would that be cause of problem/contribute to problem?
has anyone had this problem before??
how to fix? im thinking clutch master cylinder has shot a seal/ O ring? :cheers:
hard to get master cylinder out/in ?
any help would be great.
thanks guys
- Ross.
https://www.sau.com.au/forums/topic/153523-clutch-fluid-leak-under-dash/
