generally my experience as a mechanic that if you hear that noise from your shocks.....its because there leaking an not doing there job properly, and standard shocks are fluid filled.
Then they probably arnt standard shocks. Theres a difference between the sound of leaking shocks
over hard bumps and good gas shocks over hard bumps..
I duno, i dont care. All i know is they felt really good, nice and soft/firm considering the height they
sit an r33 at. I just want them GONE! Make an offer somone!
I cannot believe the lack of interest in these WHEELS!! They sit veryy very wide, the rear rims are
completely inline with the guard if not a little outside it! and all 4 rims are in absolute perfect condition.
I need this stuff gone guys just make me some reasonable offers & pick em up!
BOV, Exhaust & Spoilers are now gone!
PARTS LEFT are the Enkei Wheels & GTR Front Bar!!
once again need these gone, no room in the garage!
BUMP, I cant believe no one is jumping on these wheels! Think i may need to take more pictures of how aggressive they sit on the car!
damn shame you arent in syd. i have a set of 18x8.5 and 18x9.5 deep dish rims i wanna swap for staggered sized 17's.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
