  • Replies 51
I agree comon pplz we need to make this happen and we need to make sure that all the ppl that say "yes" are 100% in otherwise its pointless!!!!!!!:uh-huh:
It is only a game, but seriously, put any kinda weapon in a blokes hand and it no longer becomes a "game", just a challenge of who has the biggest "kahonas":D Everyone just becomes a "Rambo" wannabe......... hahahahahaha.
So comon join the fun and maybe we can have a "Skyline colour" war!!!!!!! needless to say who would win!!!
WHITE WARRIORS
:shake: :lol:
Ando
Guest | hype^ |
WHITE WARRIORS
:shake: :lol:
Ando
Xrsist.. we need to get OnARun in this so us burgendy guys can show these 'white-boys' what its all about..
very ouch Jim! :)
if you haven't been before WEAR LOTS OF LAYERS!! and for the guys, if you own one, a cricket box might be a good idea :)
I still don't understand why they supply us chicks with a hard plastic bra-thingy but give u guys no protection???
I'm suprised he hasn't responded yet.....
Any ideas on what day we are looking at, I currently have some
plans which may clash with this. But yes.. i feel a sense of adrenalin! :jump:
I think someone is going to be :headshot:
Shell its compulsary at this place to wear a cricket box of your a guy. they have a picture of what happens if you dont and you get shot. theres a sign saying "this is what happens if you wear no box". but knowing me i didnt read that sign and just laughed at it and looked underneath. im telling you now WEAR A BOX. ive never seen a bruise that big and "it" was unrecognisable.
  • 3 weeks later...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
