I'm really not sure what you mean.
The RB30 block has a predrilled and tapped hole for the new tensioner location as an RB30 only uses one tensioner and no idler on the drivers side or when looking at the block the left side of the block.
Found a pic of my block as it was being built up.
As you can see the flat surface around the place where the tensioner will go.
Mine was a Series II VL Wagon Exec NA Block.
Are the blocks you have Series 1 blocks? Do they have the oil and water lines already tapped? If not they are series 1 blocks.
Are you going to use stainless steel welsh plugs or brass ones as per pic 1?
EDIT: Also the fuel consumption I am getting is pretty damn good..
Slightly better than what the rb20t was getting. :D
The RB20t was getting around 11L/100km's.
heres the pics. i have 3 blocks like the first pic and the other is a genuine vl turbo block
I have a VL na S2 block and it looks like this.
Now I know that VLT and VL na S2 blocks are the same but if you look under the engine block number it will have a number.
6=na
8=turbo
mines a 6 :D
well its all tapped for turbo gear from the factory so its a bit wierd!
also i have another turbo block that doesnt have the machined surface for the tensioner.
so its 5 blocks in total all of which are tapped from the factory.
2 turbo blocks wearing an 8 under the engine number.only 1 has the machined surface!
3 na blocks all of which have no machined surface
dnb My block is the same as yours and it has all the oil and water lines tapped aswell. I have already had it Torqueplate bored, honed and o'ringed so I was thinking of making a washer the right shape and fill around it with devcon (steel putty) and file it back level with the other surfaces. I have bought a second tensioner instead of the idler. I also have to make an adopter plate to fit a 4wd sump as it will be going into a GTS4.
what about the na blocks that ARE tapped but have no machined surface?.
you deleted your post alf! now this looks silly
sorry, getting confused here.
Ok, i've had this convo about rb30 na blocks before with several knowledgable ppl.
Everyone says the s1 rb30 block doesnt have tapped holes for oil and doesn't have the machined surface.. but the same ppl have seen a few s1 blocks with tapped holes.
haha yeah ive had that block done aswell;( its cool though as im selling my old sohc set up to a guy who will buy this block off me as its ready to go. i was gonna do the devcon trick aswell but since i have the option to unload it and i have another block sitting there i will just get the other one machined up.
i think this had better be mentioned in the rb2530 conversion guide!
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
