I'm really not sure what you mean.
The RB30 block has a predrilled and tapped hole for the new tensioner location as an RB30 only uses one tensioner and no idler on the drivers side or when looking at the block the left side of the block.
Found a pic of my block as it was being built up.
As you can see the flat surface around the place where the tensioner will go.
Mine was a Series II VL Wagon Exec NA Block.
Are the blocks you have Series 1 blocks? Do they have the oil and water lines already tapped? If not they are series 1 blocks.
Are you going to use stainless steel welsh plugs or brass ones as per pic 1?
EDIT: Also the fuel consumption I am getting is pretty damn good..
Slightly better than what the rb20t was getting. :D
The RB20t was getting around 11L/100km's.
heres the pics. i have 3 blocks like the first pic and the other is a genuine vl turbo block
I have a VL na S2 block and it looks like this.
Now I know that VLT and VL na S2 blocks are the same but if you look under the engine block number it will have a number.
6=na
8=turbo
mines a 6 :D
well its all tapped for turbo gear from the factory so its a bit wierd!
also i have another turbo block that doesnt have the machined surface for the tensioner.
so its 5 blocks in total all of which are tapped from the factory.
2 turbo blocks wearing an 8 under the engine number.only 1 has the machined surface!
3 na blocks all of which have no machined surface
dnb My block is the same as yours and it has all the oil and water lines tapped aswell. I have already had it Torqueplate bored, honed and o'ringed so I was thinking of making a washer the right shape and fill around it with devcon (steel putty) and file it back level with the other surfaces. I have bought a second tensioner instead of the idler. I also have to make an adopter plate to fit a 4wd sump as it will be going into a GTS4.
what about the na blocks that ARE tapped but have no machined surface?.
you deleted your post alf! now this looks silly
sorry, getting confused here.
Ok, i've had this convo about rb30 na blocks before with several knowledgable ppl.
Everyone says the s1 rb30 block doesnt have tapped holes for oil and doesn't have the machined surface.. but the same ppl have seen a few s1 blocks with tapped holes.
haha yeah ive had that block done aswell;( its cool though as im selling my old sohc set up to a guy who will buy this block off me as its ready to go. i was gonna do the devcon trick aswell but since i have the option to unload it and i have another block sitting there i will just get the other one machined up.
i think this had better be mentioned in the rb2530 conversion guide!
    • ouch! how is the car now?I had sold my gtr but have been looking into some on trademe and a 260RS but I wouldnt be keen on any repairs needed on them
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
