Not sure if its already been asked or not (and theres 85 pages to search through), Im just looking for a quick answer as to wether theres any difference between the R31 RB30 and the VL RB30. I can pickup a complete R31 with an RB30E for quite a reasonable price and am looking at building it up over 12 months or so, then using my RB26 head on my current engine on it.
:D
The block and all internals are the same between the skyline and vl RB30E
The skyline does however have a few different parts, such as different size heater connections, different harmonic balancer etc etc.
But its all little stuff that wont effect a conversion such as discussed in this thread.
Hey Guys,
Can i get a VRS kit for the RB25DE (R32 non-vct version) ?
That way i will have the correct head gasket for the conversion. (Gasket without VCT oil hole)
Or have you guys got the VRS kit for the RB25 VCT version, then spent another $70 on the RB30 headgasket and thrown the RB25 gasket away?
Thanks for your help.
Hey Guys,
The R32 Non-VCT RB25DE headgasket is the same as the RB30E/T headgasket.
I bought the VRS kit for my R32 RB25DE head ($275) as I had the head rebuilt.
I then sold the stock headgasket and had supplied by the engine builder a multilayer metal heagasket that contained a O-ring type sealing ring in the middle layer.
Thats what i was getting at the GTS25 non VCT R32 would have the correct headgasket out of the packet.
You wouldn't happen to know the Nissan Part No for that kit is do you?
If not what year was the R32 GTS25, just so i get the right thing?
Thanks Again :)
I had a quick look through my pics and must have not grabed a pic of the VRS kit. :)
I was sure I had.. :)
When ordering I simply asked for a R32 RB25DE VRS kit.
It came with the usual top end gaskets (inlet/plenum/exhaust/rocker covers), valve stem seals, cam seals etc.
As a side note im selling gtr block adaptors now with all the low down on how to make it work, as there is a fair bit of work involved. So if anyone is interested PM. I have spent around $1500 in material and machining costs to perfect this thing and let me tell you it isnt worth the 2g RIPS and AVO want to make it work!!!
I actually do have a few questions I want to confirm.
The Goal is this..
250rwkw - under 300rwkw.
For Daily street use. Possible track outings.. (possible meaning once or twice a year and that's a maybe!!!)
mainly just a torquey street car.
engine will end up in a 4 door R32 sedan
1.)R32 RB25DE valve springs.
If I am not rebuilding the head and simply want to have the seat pressure tested, how is this done?
What rating are the standard R32 RB25DE springs and what are the RB26DETT springs rating?
(EG, the 25de has 10 lb springs and the 26dett has 15lb springs... )
what are the true ratings?
How much are stock 26dett valve springs?
2.)For my Goal, will the stock 30E pistons be fine with the 8.3:1 comp ratio and a turbo which will need 1Bar to produce the power?
3.)Head Gasket - Stock RB30E gasket and O-ring the block good enough for my goal?
4.)exhaust manifold - I'm unsure of what part needs to be removed/grinded from the water gallery in the RB30E block
to make the gasket and manifold fit.. does anyone have pics of the bottom end before and after the removal?
5.)Sump - removal of the fins inside the RB20DET sump. how much do you have to remove off them? or is it complete removal?
Won't this cause oil surge/starvation problems?
6.)Pistons - Stock RB30E pistons will be used. What was the process called that can be done to pistons
to make them not absorb as much heat.. I read it but can't find it again..
I believe there was also a cost per piston.. anyone remember or find it?
7.)Quench - Do I need to worry about this is I am using stock pistons?
8.)CR - Should I bother removing some height off the block to increase the compression ratio?
if so, how much off the bottom end and how much off the head?
Remember this is a budget/for the street build.
9.)RODS - Prepped rods.. what is Prepping? what was the cost per rod?
10.)CRANK - linishing... again, what is it and what is the cost?
11.)Oil pump - RB25DET oil pump is what I plan to use.. Is second hand ok?
Can you tell if they are faulty by visually inspecting them?
12.)ECU - Obviously R32 GTST ecu to run in. But to support my goal, Can the Stock ECU be chipped to handle?
I mean to reach that power goal, surely a Z32 or bigger AFM is required along with injectors and FPR.
Can you run these with a CHIPPED stock ECU?
Sydney kid... what was used for your very first RB30det car that had 475HP?
13.)injectors - Are we certain that the RB25DE uses the same 270cc top feed, high impedance injectors that the RB20DET uses?
14.)Turbo - Due to the torquey nature of this engine, would PLAIN bearing turbo's be a better option
as I "ASSUME" (I know.. dangerous thing to do) they would spool up slower than ball bearing turbos and make the car
more controllable as it comes on boost?
Also, for up to 300rwkw, what internally gated turbo would fall in to a budget of under $2500? AND... fit the stock manifold.
15.)Intercooler - rb26dett intercoolers good enough?
16.)Air box - Stock R32 GTST air box with some form of hi flowing panel filter good enoug?
17.)BOV - surely the stock GTST ones are going to struggle to hold the pressure.. Can GTR stock plumback bovs be adapted and used successfully?
when they plumback, are there 2 return lines back to the air intake pipe or 1?
18.)Oil cooler - second hand Jap VR4 ones good enough with new custom lines? I can't remember the measurement but surely they would be better than nothing.
And if I was to set up a waterspray system for the intercooler, what's to stop me setting up another jet for the oil cooler?
19.)Those who put this engine in to an R32, there was discussion of brakets being made for the engine to mount it lower.
Anypics? Joel or Darren, how did you guys go? still using stock bonnet?
still using stock antisway bar under the car?
AAAAAAND I'm done.. (EDIT obviously I wasn't cause I just added from number 15 onwards..)
thanks
I believe you are talking about cermaic coating the pistons.
I've been quoted $38 a piston from HPC(RB30E forgies) don't forget the valves need to be done to get the full advantage of ceramic coating, SK knows more about this topic.
:P
We ceramic coat the piston crowns, the valve heads, the combustion chambers and the exhaust ports. We also oil retention coat the piston skirts.:rant:
I know every little bit helps but is it necessary for a street car?
I know I set my goal high but I will probably putt around the streets with power in between 200-250rwkw and be happy due to the torque compared to my old RB20 or even my current SR20.
so can you answer my 19 question SK?
Oh my, so many questions in one post GTST, lucky for you I am patient. Most people would just tell you to look up the thread as it is all there. My suggestions follow your questions;
If I am not rebuilding the head and simply want to have the seat pressure tested, how is this done? What rating are the standard R32 RB25DE springs and what are the RB26DETT springs rating? (EG, the 25de has 10 lb springs and the 26dett has 15lb springs... ) what are the true ratings? How much are stock 26dett valve springs?
To measure seat pressure you need a valve spring pressure tester anda dial gauge.
RB26DETT valve springs are rated to handle boost, so 15 psi stronger than an N/A valve spring. RB26DETT valve springs are rated to handle 8,000 rpm, so another 10 psi stronger to hande that higher rpm.
You can't fit GTR valve springs to RB25 cylinder heads. They are different heights and diameters. For example RB25 vlave springs are shorter to allow for the hydraulic followers. You would have to change the complete valve train, cams valves, valve springs, colletts, followers and shims.
No problems, it will be bit doughy with compression that low.
Yep
It is about 30 seconds work with the die grinder and it is bloody obvious. Just the tips of the lumps on the gallery down the side of the engine.
5.)Sump - removal of the fins inside the RB20DET sump. how much do you have to remove off them? or is it complete removal?  Won't this cause oil surge/starvation problems?
Just a small bend. makes no difference,
Ceramic coating, see previous post.
But you are not using the stock head.
Nope
Preparing usually means balancing and grinding off any small imperfections. Balancing is very important, the rest is debateable as to benefit.
Polishing the bearing surfaces.
11.)Oil pump - RB25DET oil pump is what I plan to use.. Is second hand ok? Can you tell if they are faulty by visually inspecting them?
Not really, you can pick a really stuffed one when you pull it apart, it will be all scored and marked. To pick a slightly worn one get your machine shop to measure it up internally.
Yep
13.)I mean to reach that power goal, surely a Z32 or bigger AFM is required along with injectors and FPR.
Yep
14.) Can you run these with a CHIPPED stock ECU?
Yep, but the tuner really needs to know his stuff
15.) Sydney kid... what was used for your very first RB30det car that had 475HP?
Motec M4A
16.)injectors - Are we certain that the RB25DE uses the same 270cc top feed, high impedance injectors that the RB20DET uses?
Sorry can't help, I used the RB20 inlet manifold, GTR injectors ands rail
17.)Turbo - Due to the torquey nature of this engine, would PLAIN bearing turbo's be a better option as I "ASSUME" (I know.. dangerous thing to do) they would spool up slower than ball bearing turbos and make the car more controllable as it comes on boost?
Sorry can't help, I never use plain bearing turbos
18.) Also, for up to 300rwkw, what internally gated turbo would fall in to a budget of under $2500? AND... fit the stock manifold.
Garret GT3040
R33/34 GTR shooooot yes.
Yep but you might find the rubber pipe from the AFM to the turbo gets sucked closed. Best replaced with an alloy one. See Bass he is making them.
17.)BOV - surely the stock GTST ones are going to struggle to hold the pressure.. Can GTR stock plumback bovs be adapted and used successfully? when they plumback, are there 2 return lines back to the air intake pipe or 1?
Hard to beat those standard GTR BOV's. One pipe back to the inlet.
Yep
The amount of water you would have to carry might slow the car down. Plus what happens when you run out of water? Hot engine?
19.)Those who put this engine in to an R32, there was discussion of brakets being made for the engine to mount it lower. Anypics? Joel or Darren, how did you guys go? still using stock bonnet? still using stock antisway bar under the car?
Ours used a SubZero Plenum and went straight in, no engine mount mods. Also had a big Whiteline stabiliser bar (standard shape) The RB26 cylinder headed RB31DET's fit straight in as well
20.)AAAAAAND I'm done..
Thank heavens, my fingers where wearing out:cheers:
Depends on tune. A bad one can kill an engine not a hp figure.
sit a rb20/25 manifold on the long motor...you will then see what needs 2 be removed....not much, just dont go nuts.
i used the rb20 sump and my fins were just bent down to clear the crank.
yes.
Im using a rb20 highflow (been told it a t3 /t4 hybrid as well?...) spool time.....hmmm.....none. Boost is instant throttle response.
My engine mounts ere just redrilled to drop the motor here it sits....12mm one side and 15mm the other i think...?
Joels ic piping is std, and clears the bonnet. Mine uses the other route over the radiator etc. and i had to chop the bonnet structure to make it "sort of" fit :cheers: antisway is std, but my strutbrace dont fit anymore :cheers:
    • Greg speaks wisdom. These dirty old Datsuns are only value when they are cheap. When they are not cheap, there is no value. Sounds contradictory, but it's true. We are now 20 years past the hey day of modifying cheap 90s JDM cars for small amounts of money. This is a different world. If you are rich and can afford not to care about what is effectively wasting money on an old Datto shitter, then I have no reason to argue against it. But if you are wanting to experience what we all experienced back in 2005 (and I bought my car last century!) then there is no way to do it.
    • Short answer: No. Medium answer: No, because you still need to conjure the things out of thin air to bolt them to a NA to make it a NA+T. Long Answer: No - The things you need to conjure - meaning a turbo, intercooling, manifolds, exhaust, intake/manifold/piping, clutch, injectors, fuel pump, AFM (?), ECU + Wiring (woo, N/A loom fun) have to come from somewhere. You could have many scavenged these things from an OEM car that someone had upgraded from and use some of these. This will be cost prohibitive now, especially so in the USA. You'd probably pay the same for newer, upgraded components that are better than old OEM stuff from 25-30 years ago. None of these big ticket items are re-usable for the N/A car. Why not buy new and upgrade while you're there? The only real consideration is turbo and fuel sizing and determining whether you want to stay within the bounds of the OEM engine or get into rebuild territory. These limits ARE lower with a N/A motor and especially N/A gearbox at the starting point. And if you're gonna upgrade those then you may as well consider having them built to begin with. Because everyone here knows you're never far from that next engine rebuild once you start making the power you want... The cars you see on the internet and SAU etc have been built over decades. If you're really clued in... you would sell your US car to somebody for what you paid for it. You would then scour AU JDM pages or SAU and buy a car like Dose's on this forum with your powerful American Dollar. This will save you so much money in the long term. Importing it could be tricky. Or it might not because USA. I have long said the only reason 90's Japanese stuff took off was because a) Japanese people had Japanese cars so that is what they used b) Australians could import these cars to Australia with very minimal changes and use them on the road here c) Neither country had well-priced access to US or EU Sports Cars. I don't believe the JDM scene would have taken off in Australia at all if we had EU priced EU BMW M offerings, or more especially the AUS V8 Scene would never have existed if we had the multitude of US cars like Camaros, Mustangs, Corvettes at the prices you folks do. After all - Do the math. I would say put a V8 in your R34 and that's the smart way forward. It is. I did it. I know this from my own experience. But at that point there's no reason to simply not buy a C5 or C6? It would be simpler and easier and cheaper and bette-
    • Reading all this... hurts lol. I have an ENR34 5MT and I paid an inflated USA price for the car alone, had to do tons of preventative maintenance past that, and so I'm over $30K USD into the car already and haven't even touched power.  I wanted to +t it. Not even trying to make GTR numbers, I'd be happy with 250hp.  Can I get away with paying much less to make that happen?
    • Damn you’ve done well, definitely snapping necks.
    • Great weekend and event. Open fire at the caravan park, perfect weather all day and a great feed and a couple of drinks at at awesome country pub.
