I thought that the vl rb30 block or sump was unable to be put into the gtr cause of the driveline?? thus why anyone who wants the 3ltr bottom end in the gtr goes for the 25k os giken ones.....any comments??
  • 5 weeks later...
I checked out how well the runners line up when bolting the inlet manifold and plenum together.
It appears no 5 & 6 runners line up perfectly with no lip where as all the rest seem to be mis-aligned.
In order of worse to best:
3,2,1,4. No 5 & 6 don't require any hacking :)
Could it be possible that the 3,2,1,4 runners have a higher degree of turbulence in turn could this possibly be the problem to high powered RB's leaning out the rear cyclinders slightly (no turbulence in 5 & 6 in turn more air flow)?
The question is should I grab the dremel out and get to it or leave it?
I also attacked the rocker covers with paint stripper. Underneath all that paint is what looks almost like chrome with a little bit of polishing. I'm going to repaint them black and have a chrome/black colour scheme under the bonnet. Polish up the plenum etc..
Hey -Joel-
Can't access your new version of the rb30diy guide? somthing with yahoo?
how much out are the runners? is it only a little? if its an easy job then go for it. why not have everything matching as much as posbile? surely it can't hurt.
If its not and you plan on making even more power later on. Then I would say leave it for now and then get custom ones later on when you require it.
If you do end up doing post pic's :)
Great thread guys,
I have been reading your posts for some time and finally thought that I should add something.
My first point relates to the differences between series one and two blocks. Some series one blocks have all the necessary oil and water provisions ready for use and do not require any drilling.
The major difference between the two blocks is on the front of the engine. The series two blocks have a machined flat surface with a hole drilled and tapped in the middle of it that you can locate your idler pulley on. The series one blocks do not have this flat surface and require a little fabrication to locate the pulley there.( Anyone who has issue 21 of Zoom magazine with the green Torana on the cover will be able to see that the RB30DE engine featured has had metal putty used to create a surface to mount the pulley). I discovered this the hard way almost 3 years ago.
Secondly, using RB25DE pistons gives a very high CR(10.5:1) not a low one.
Series 8 RX7 injectors are side feed and will fit the RB25DET fuel rail. Due to the rotary's use of primary and secondary injectors they come in 2 sizes. It has been a while since I looked at injectors so I can't remember the exact sizes but both are quite large and work better than the earlier 550cc top feed items.
You have stated that RB20 fuel rails will fit R33 intakes. Only the ECCS rails can be modified to fit. The NICS rail is completely different.
The bracket for your power steering pump & aircon comp will also need slight modification to fit due to one mounting hole on the block sticking out about an inch. Measure the difference accurately and simply cut the bracket down to suit.
I hope this little bit of info helps someone.
Be wary of R31s..........
Hey guys
I think I’m about ready to get onto the building of my beast.
I have
Rb30E Block - been honed and cleaned
Rb30E Crank - Balanced
Rb30E Rods - Balanced, Cleaned and polished
Rb30E Pistons - Balanced, Cleaned and polished
ACL Big End/Main Bearings
ACL Rod Bearings
ACL Piston Rings
Dayco Timing belt
ProTorque Rb30 Head Gasket
GBC Rb30 Tensioner Bearing (for timing belt)
Devcon Plastic Steel Epoxy (To fill hole in Rb25det head)
Everything else is in the car on the 25det
As far as I can tell I’m all ready to go :D
Accept for a Copper T Piece for the oil pressure sensor.
Copper line to run to the head and tap the hole in the head. As well as numerous amounts of oils to lube it up on assembly.
Just have to paint the block and put it all together
What do you guys recommend for the running in process?
What I have been told is. Put it together and fill it with mineral oil - do 50km's of fairly low speed high gear driving. Drop the oil. More mineral oil in. do 450km's of the same sort of driving. Drop the oil. Do 500kms of mixed driving - normal and high gear low speed. Drop the oil. Do 500km's of just running around (city driving bit of highway, down the shops etc) and then should be ready to go.
Just wanted to say a quick thanks to all evolved in this as it makes it a lot easier!
Thanks guys
I have a crack in my current RB25DET block, and i have heard all the storys about the RB30, so i have been looking into it for a while now.
Ok so from what i can tell i need a S2 RB30 block to make things a little easier, new pistons? (i would like to run same comp as current setup).
And basically rebuild the whole bottom end. no big deal
what cost are you looking at for those hyperetetic? pistons and if you are chasing no more than 400 crank hp can you just use ACL pistons?
what i want to know is what have ppl done with the oil gallery for the VCT on the RB25DET head? i would like to retain this if at all possible.
How much is the JUN oil pump thing?
what turbo can you use? I deally i would love to use a HKS GT30 or similar but at this current time and short notice of engine rebuild funds do not permit. I was thinking a VG30 turbo and possibly high flow or atleast enlarge the wastegate?
i am going to get my inlet and exhaust manifolds power ported at the same time.
i have been told this causes over fueling which may mean i can use the injectors still? Running a microtech at the moment by the way so tuning is not a problem.
any help would be greatly appreciated, i am so pissed off that i have only had my car 2 months and not really lit the wick in terms of power (driven to work mainly) and this happens, car was pretty much doctored up to sell (waterpump coated inside with heaps of water sealant crap). but hopefully its going to benefit me in some way.
Imagine Hybrid car with hybrid engine? yes please!!
Does anyone read this thread anymore?
I really need to know whats the deal with this swap as i am going to look at a VL Sii block this weekend and i want to know if its worth my while doing ths swap, or just get a new RB25 block?
i also want to know more about the VCT mod that you guys are doing cos it doesn't seem too clear to me
Yes we do read it still :)
Cheapest option - do what RIPS does (as far as i know), buy a rb30e short motor, new rings and bearings. Buy a rb25de head, polish combustion chambers, away u go. when it blows costs less than 2g for complete motor ;)
As far as vvt goes - im not using it cos its not in the 32, and thank god cos it sounds a hassle.
Normal rb25 oil pump will do.
Std. pistons will cope to 250rwkw if tuning is good.
HKS GT30 series is ideal for this engine. I will be running mine on for a month or so on the std rb20 turb that has been high flowed b4.
Or u could go out and spend the 10K + that it costs to do the perfomance upgrade side of it.
Hmm, ive already got a RB25DET head and i have access to several complete RB30 blocks all in ok cond for cheap
they would really only need bearings and rings and freshen up
Im not to worried if it costs a little bit, but i don't want to spend any more than $3k (ive got everything else in place ECU, fuel system etc)
Keep your VVT. Simply tee into an oil feel (at your pressure sensor will work) and run a line up to the head. If you look back through this thread and at the page Joel has been compiling you will see where on the head to run it to.
I had no trouble with mine and I haven't heard of any problems. Because of the slight interference fit it is easier to remove the transmission from the car, fit it to the engine and install the complete engine-transmission together as a unit. Trying to lower the engine into the engine bay and then bolt it up is very difficult.
Just remember to drain your gearbox before you remove it.
Geoff.
I remember fitting the VL 5 Speed to my VL... What a nightmare.. I ended up cracking the exhaust manifold studs.. Stupid me, I should have removed the exhaust before I decided to get angry with the thing and force the back of the engine down as the firewall was stopping the gearbox from sliding in.
I threw many a hammers, sockets & spanners that night.
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
    • Ahh. Well the block damage is a problem, you really need to run a tap or thread chaser through it to see if the threads can be saved, but any chips are likely to be bottom end bound which is bad. Earls seem to have what you need if you want to stick with mounting direct on the block: https://rceperformance.com.au/parts/earls-straight-adapter-1-8-npt-male-to-1-8-bspt-female.html, but as I said above I'd recommend remote mounting the sender
    • I'm not quite understanding or I'm missing steps here, (I appreciate people are trying to inform my brain but I am of the dumb, especially today) - All I want to do is mount the male BSPT of the OEM sender into the system somewhere without it snapping the adapter via vibration. The Nissan sender has a male 1/8 BSPT output. The block has a (very destroyed) 1/8 NPT input. I'm not really sure how a lathe assists with that, and also don't know anybody with a lathe, nor specifically what I would want to buy. I'm not really sure how adding additional adapters creates a better, more leak proof resilient seal here.
