hey guys,
i have an r32 gts-t and my car seems 2 jerk in 2nd and 3rd when i floor it from 4000rpm onwards.
it feels like the car wants 2 go but sumthing is holding it back. Something must be causing it struggle.
This doesnt happen all the time but does happen
Any help would be appreciated thanx guysss
:ninja::):laugh:
https://www.sau.com.au/forums/topic/154372-car-jerks-at-times-plz-help/
Too vague, we'd need more info than that, one thing I'm 90% sure of is that its' either fuel, electrical, or mechanically related though......lol.
lol... well when it happens the car doesnt flow smoothly sorta like somethings cutting out therefore it jerks so it could be electrical.
a mate of mine seems to think that it could have something to do with my engine coils, could that be right?
thanx
Nah, you can buy them in the FS section here. Then you just swap it for one on the motor, and keep swapping it until you find the faulty one.
Takes like 2 minutes to swap a coil once the valley cover is off.
At what revs does it jerk?
hmm sounds good might chek it out thanx
it starts to jerk between 3500 and 5000 after that its usualy finee
If it was a coil and above 3500rpm, I've reckon it would keep missing right through the rev range once it started. Secondary winding [if nissan coils have them, not sure] collapse would be at or over 3500.
Maybe the problem is elsewhere.
the car is pretty much standard apart from a cat back exhaust, pod a BOV.
standard computer
might change sparkies................
just out of curiosity how much would a bosch fuel pump be and will it change anything performance wise????
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
