OHHHHHH spewing, i left my in car light on overnight, woke up and the f%$# is dead as, ive heard your not allowed to jump start skylines or any turbo because it may stuff up the turbo or somethin.........do i just remove the battery and charge it seperately or what, cheers guys. :laugh:
https://www.sau.com.au/forums/topic/154601-car-battery/
Disconect your battery , then charge it . If it's a a 33 , just be carefull of your rear speakers as they might atempt to pull the spaner towards them as you undo the terminals. A rubber insulated handle type is best.
Another thing , with the battery from a 33 , you dont need to open the cell caps .
good luck
By the way , since my gtr isnt going anywhere lately , I ve had to charge mine up . A good charger shouldn't cost more than $24.95.
If you buy one from any mitre10 tomorow , you should get 15% off.
Edited by savage GTR
https://www.sau.com.au/forums/topic/154601-car-battery/#findComment-2875753
good luck
cheers for that savage,:laugh:.
https://www.sau.com.au/forums/topic/154601-car-battery/#findComment-2875788
I jump start My 32 GTR when ever its flat. AS LONG AS you have a GOOD set of jumper leads that have the surge protector in them all the battery terminal that you are connecting the leads to are clean and you connect them in the right sequence you will never have a problem. In saying correct sequence you connect your earth LAST and it is the FIRST lead you will take off after your car has started. NEVER disconnect the Positve first as thats where voltage spike can occur and poof goes the ecu if you are real unlucky. This is the same when you disconnect your battery when you want to remove it. I don't know where you heard you can't jump start turbo cars from, I can't say i've ever heard of that before. If the battery is dead flat you would be better off charging it over night, or unless you can go for a good long drive in the car after you jump start it. Couple hrs or more.
https://www.sau.com.au/forums/topic/154601-car-battery/#findComment-2876091
Its actually much healthier and better for the battery to charge on a charger if possible. If the car is flat and its not an emergency, charge it on an external charger all the way. Otherwise even if you can spare 10-20 minutes it is worth it. The excess current when a battery is dead flat can shorten the life of it and also it puts excessive strain on your alternator.
https://www.sau.com.au/forums/topic/154601-car-battery/#findComment-2876149
Technically you can spike and blow up your ECU, but as someone said it is more of an issue if you are a twit (not looking at anyone on here Vange) and short the battery by hooking the leads up wrong.
Best bet is to not put the negative on the battery terminal, but rather connect it to a ground point on your engine. For some reason this is less risky to your ECU (told to me by an RAA guy).
https://www.sau.com.au/forums/topic/154601-car-battery/#findComment-2879009
Actually it makes no difference to the ECU where you ground it. Its about not introducing a spark near the battery - theres a small but real chance the hydrogen gas from a charging battery can cause explosions when you disconnect the leads. That's why they always say disconnect the earth away from the battery first.
https://www.sau.com.au/forums/topic/154601-car-battery/#findComment-2879140
that's correct...
best to jump start it from under the bonnet....that's why that + terminal is there and connect earth - to your strut tower bolt.
also, your electronics have nothing to do with your turbo mate....not an issue for it. a 33 (turbo or not) is exactly the same as any other efi car out there.
Edited by Ryanrb25
https://www.sau.com.au/forums/topic/154601-car-battery/#findComment-2881587
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
