OHHHHHH spewing, i left my in car light on overnight, woke up and the f%$# is dead as, ive heard your not allowed to jump start skylines or any turbo because it may stuff up the turbo or somethin.........do i just remove the battery and charge it seperately or what, cheers guys. :laugh:
https://www.sau.com.au/forums/topic/154601-car-battery/
Disconect your battery , then charge it . If it's a a 33 , just be carefull of your rear speakers as they might atempt to pull the spaner towards them as you undo the terminals. A rubber insulated handle type is best.
Another thing , with the battery from a 33 , you dont need to open the cell caps .
good luck
By the way , since my gtr isnt going anywhere lately , I ve had to charge mine up . A good charger shouldn't cost more than $24.95.
If you buy one from any mitre10 tomorow , you should get 15% off.
Edited by savage GTR
https://www.sau.com.au/forums/topic/154601-car-battery/#findComment-2875753
good luck
cheers for that savage,:laugh:.
https://www.sau.com.au/forums/topic/154601-car-battery/#findComment-2875788
I jump start My 32 GTR when ever its flat. AS LONG AS you have a GOOD set of jumper leads that have the surge protector in them all the battery terminal that you are connecting the leads to are clean and you connect them in the right sequence you will never have a problem. In saying correct sequence you connect your earth LAST and it is the FIRST lead you will take off after your car has started. NEVER disconnect the Positve first as thats where voltage spike can occur and poof goes the ecu if you are real unlucky. This is the same when you disconnect your battery when you want to remove it. I don't know where you heard you can't jump start turbo cars from, I can't say i've ever heard of that before. If the battery is dead flat you would be better off charging it over night, or unless you can go for a good long drive in the car after you jump start it. Couple hrs or more.
https://www.sau.com.au/forums/topic/154601-car-battery/#findComment-2876091
Its actually much healthier and better for the battery to charge on a charger if possible. If the car is flat and its not an emergency, charge it on an external charger all the way. Otherwise even if you can spare 10-20 minutes it is worth it. The excess current when a battery is dead flat can shorten the life of it and also it puts excessive strain on your alternator.
https://www.sau.com.au/forums/topic/154601-car-battery/#findComment-2876149
Technically you can spike and blow up your ECU, but as someone said it is more of an issue if you are a twit (not looking at anyone on here Vange) and short the battery by hooking the leads up wrong.
Best bet is to not put the negative on the battery terminal, but rather connect it to a ground point on your engine. For some reason this is less risky to your ECU (told to me by an RAA guy).
https://www.sau.com.au/forums/topic/154601-car-battery/#findComment-2879009
Actually it makes no difference to the ECU where you ground it. Its about not introducing a spark near the battery - theres a small but real chance the hydrogen gas from a charging battery can cause explosions when you disconnect the leads. That's why they always say disconnect the earth away from the battery first.
https://www.sau.com.au/forums/topic/154601-car-battery/#findComment-2879140
that's correct...
best to jump start it from under the bonnet....that's why that + terminal is there and connect earth - to your strut tower bolt.
also, your electronics have nothing to do with your turbo mate....not an issue for it. a 33 (turbo or not) is exactly the same as any other efi car out there.
Edited by Ryanrb25
https://www.sau.com.au/forums/topic/154601-car-battery/#findComment-2881587
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
