Surely theres gotta be some one who is willing to sell this?
It must be an ORIGINAL GTR bar, dont want any silly fibreglass thing!
I've been looking for an original GTR bar for more than 4 months now!!!
COME ON... SOME BODY! SELL ME YOUR BAR!
UPDATE: I need a GTR reinforcement (reo) for a R33 GTR front bar..
Edited by Janissary
https://www.sau.com.au/forums/topic/155025-r33-gtr-reinforcement-front-reo/
lol...i had exact same issues a few mths ago with my R33 GTR....u should double check this....but i believe an R32 GTR re-o is same as an R33 GTR one.....coz wen mine was in the panel beater we put an R32 GTR and R33 GTR re-o side by side and they were the same....if u went for an R33 GTS-T re-o......any decent panel beater should be able to weld the thing to suit an R33 GTR....do u have any part of ur original re-o left over? if so its just a matter of chopping and welding.....i aint a panel beater sorry....but after 2-3 mths of being in same situation as u...i learnt a thing or two.
hope this helps.
p.s.....if u got a GTR.....DON'T go for one of those cheap aftermarket fibreglass front bars! coz 2 weeks later u'll be back in the panel beaters getting it repaired.
Thanks for the tip nismo83..
However i would prefer GTR reo for many reasons.. From what I've heard, a GTR bar fitted to a modified GTST reo doesn't look the best, the bar can sag below the headlights and other parts as well.. Overall, it wouldn't look 100% original!
Can a reo be bought from Nissan in Japan?
Edited by Janissary
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
