Well for the peolple who have heard but havn't seen anything about the build, below is a link to a thread started in SA about the Twin Turbo LS1 R34 that George and Theo of GT Autosound have been building up! And if your familiar to thier S15 Drag and S15 Drift car, you will know that this will have everything and anything on it! It made its debut on a charity cruise on the weekend and i looks even better in the flesh!
Click and enjoy........
http://www.skylinesaustralia.com/forums/in...howtopic=133132
https://www.sau.com.au/forums/topic/155083-gt-autosounds-twin-turbo-ls1-r34/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
