  • Replies 148
  • 3 months later...
  • 1 month later...
  • 4 weeks later...
Did a quick chop of this
Tried to fix the bumper but looked too fake in the end so i just chopped in another bumper including lights, despoilered, removed the windscreen sticker, did a partial job on the guards but will try again some othertime to fix it also did a colour change.
If GODZILLA did a turd, it would look like that NEMESIS skyline!!
islander_s13, good job of turning into something respectable..
yeh thanx man, as i said once that bumper was replaced it was looking good again then just blended the front guard into the body, rear guard was just too hard to fix unless i chopped in a whole new back half lol
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
