Hi guys I have a page guard alarm system in my car which i had installed shortly after purchasing the car and have not had any problems up untill now. The unit has a lcd (i think) pager remote which takes 1 AAA battery. This morning when i went to open the car, the battery in the pager had gone flat. Problem is i keep some spare batteries in the glove box incase one goes when i'm out somewhere.
So i had to open the car with the key - which made the alarm go off as expected, now usually i would then just replace the battery and stop the alarm by pushing one of the buttons on the pager - but it would not stop, i tried closing the doors, different batteries, kill switch, everything and the alarm would not disengage. It's like as if the alarm no longer corresponds with the remote / pager. Ususally when you disarm the alarm, the pager says 'disarm' then is shows a pic of a lambo with a moving red arrow to clarify that it has been dis-armed. When you press the button now the remote says 'arm' and has no follow up picture or anything. I ended up having to find the module for the system and dis-connect the main harness to turn it off... I know this sounds a bit technical but i was hoping there could be some alarm guru's out ther who could possibly shed some light on the situation.
Thanks guys
Edited by R33silverS2
https://www.sau.com.au/forums/topic/155616-page-guard-alarm-system/
good you know where the module is :) go one better and take it out. that is a common problem with them. antenna dies of the unit s lose programming. if you have the instructions and the spare remote - rekey both of them to the unit.
I have intructuctions but only one remote. If i take the module out is ther anything i can do to try and fix it?
nope not without the other one. you need it to reset the unit.
Thanks for your help - can the unit be reset without too much difficulty? as in will i be able to take it to the guy who installed it and could he most likely fix this problem, or is my alarm totally shagged now?
had one of these on my r33. Shit alarm thats all i can say. Once it was raining heavily outside when i was driving the car, alarm started goin ape shit on the road. woudlnt respond to any buttons i was pushing . IT was like it was ignoring me haha. But anyhow pretty embaressing (people prob thought i was driving a stolen car lol) luckily it wasnt to far from home. A couple of other times in hot weather when i pushed the unlock door button the alarm woudlnt respond. My 2 cents
Oh that sucks, you know you get an alarm with all the bells and whistles and it's just got more sh#t that can go wrong with it. I just want a simple alarm and immobiliser no more of this pager and what not.
I do such a thing however you are in MLB and I'm not.
what you are REALLY after is a GSM paging unit with a decent alarm. that is the same idea has what you have and the insurance company will like it :happy:
what you are REALLY after is a GSM paging unit with a decent alarm. that is the same idea has what you have and the insurance company will like it :huh:
Yeh well i guess i'll start having to look around for what options i have-damn annoying though cos i thought i had the alarm stuff over and one with. whats your opinion on vipers?
460/480 XV - good. 791 - nope.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
