Hey mate I worked back late last night so I couldnt get some pics for you but to answer your question when we did mine we had to cut a strip along the bottom of the support bar so the cooler could fit plus we had to trim the front bar quite a bit for it to fit.
Chris
No worries mate, if you can get some pics when yourve got a bit of spare time that would be sweet
Yea i thought the support bar would need a bit of cutting, it looks pretty tight in there, thats not a problem tho, i cut the support bar on my old r32 so should be easy >_<
  • Replies 113
ive got this blitz fmic kit on my 32 and the standard front bar was lower the the bottom pipe and my new front bar (vertex) sits alot lower ive had it on for about a year and havnt got a scratch on it. i always scrape my front bar on drive ways and shit but have never hit the bottom pipe
Got any pics dude?? theres probly no point posting pics of yours as its not a r33, but if u do post some pics that would be kool.
Does any member/trader on this forum sell the Blitz lm fmic for a r33?? im thinking it might be cheaper to import one from aussie rather than getting one from nengun.
I doubt you'll beat nenguns price...
Yea i know,nengun is bloody cheap :D, but i may get charged importing tax and stuff like that if they display how much it is worth, if i buy it from someone in aussie i may be able to get them to write the value a little lower than its actually worth so hopefully i wouldnt get charged importing tax etc etc.
Im looking forward to you and alphanumeric posting up some more pics, hopefully i will make my mind up when i see some decent shots lol :happy:
Nengun never write the real value on items sent, they do that so as not to attract potential thieves to expensive items...they'll also remove all logos etc from the packaging if you want them to, so that its just a random box to anyone handling it...
When I got mine, their price was unbeatable, but there's always a chance that it could take ages for them to send it...I decided to pay roughly an extra $100 and buy it from homerrules on NS.com (he's a trader) as it was guaranteed to be delivered to my door quickly....it took about 5 days once he received the cash and made the order etc.
So what did it cost you all up (aussie dollars) from "homerrules' if you dont mind me asking, if its not much more then nengun i may send him a p.m and see what he can do, its going to cost me $1080 nzd from nengun delivered which is a very good price, but then there is the risk of getting charged importing fees, someone loosing the package (i dont think that would happen), damage etc ,ive heard nothing but good things about nengun so im not really to worried if i do decide to buy from them.
Just received a reply from homerrules on NS.com and have been quoted $1300 AUD delivered, which is $1466 NZD :), i think i will go with nengun instead, if i decide to get one :P lol.
Some info.
I have seen these and other coolers fitted to R33's where the owner said they had to cut the front bar a fair bit and they were almost all mounted incorrectly.
Basically there are 2 main things you can do to get the pipe (and the whole thing) to sit higher. One is to mount the cooler on a slight angle, bottom more to the rear of the car. The other is to use a rubber mallet to bash the bits of the radiator support panel that stick out back a little. I moved mine up about 3 cm just that (was an R34 though).
Also there are two mounting holes for the brackets that go on the top of the cooler. Some people use the lower one when you need to use the higher one. Need to relocate the horn.
This bracket is the only one that is not attached to the pipes. I think I have the R33 one lying around somewhere.
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
