Looking for an R33 GTS-T no more than $11,000
-Must be manual and not Burgandy or Red in colour.
Please send pics and specs to [email protected]
Will also swap my VL Calais Turbo for R33 GTS-T http://www.calaisturbo.com.au/showthread.p...041#post1284041
Thanks
Edited by BillyMako
https://www.sau.com.au/forums/topic/155627-wanted-r33-gts-t-manual/
im in sydney. could probably work something out in regards to you having to come over here so probz take a little more out of the asking price.
  • 4 weeks later...
'93 R33 GTS-T 178,000k's
5sp
10,000k's on the timing belt, other belts, tensioner/idler bearings, radiator core and water pump.
12,000k's on the rims and tyres (18" AMG ones)
15,000k's on the clutch (just OEM one)
600x300x76 FMIC with 3" piping
32mm 2 row rad (std is 18mm 1 row)
exhaust
dual stage boost controller
oil changed every 5k kms along with filter.
everything runs fine.
However it has some damage and 2 panels are a different colour, the guy before me tried to fix some scratch marks.
Got a quote for $750 to fix it the rear end and re-align it all (no painting factored in though cause it'll be best to fully respray it anyway).
Comes with a new front bar.
And also big dent in rear bar where someone reversed into it or something, should just need another rear, might be able to get the dent taken out, don't know.
And the windscreen has a far crack on the passenger side (passed rego twice like that though)
It's all booked in to be fixed up, but yeah if your handy with a spray gun might be worth it.
looking around the 10k ono mark.
Edited by Rudager
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
