well for starters, if the oil pressure problem is caused by a lean out then its too late for the motor so go and get a compression test. It sounds to me like your guage is playing up (i.e not reading right), your rough idle would be from the 040 and the fuel smell would be because skylines have what is basically a cold start choke (adds more fuel until its upto operating temperature). hope that helps :P
^^yeh i hope ur right with the cold start thing, i have heard that there is something like that but im pretty sure i didnt smell it until recently.
with the running lean thing, i have nfi whether thats the problem. i still have my money on it being a oil pump. but there are many characteristics that dont seem to lead to being oil pump, if anything they lead to not having enough oil, but like i said i have checked the dip stick and it seems all fine.
Edited by nisskid
ok so more info:
when i secure the dipstick tightly the issue doesnt seem to be bad, when i sit it on there loose it comes back. i assume this is what its like all the time as after driving it slowly comes out a bit and sits loosely. also revs drop and rise simultaneously with pulling the dipstick in and out.
so its looking like a bit of crankcase pressure, but i dont seem to be burning any oil, so i dont know about rings. i also made 141kw's recently with just 3inch catback, pod (un-heat shielded) and chinese copy FMIC (unboosted, so no real gains yet) with the above A:F's, so it doesnt really seem like my engine is in all too bad condition, still seems to pull pretty hard throughout the rev range, possible a bit more vibrations (or it could be in my head) but that would make sense with low oil pressure.
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
