ok, well, 2 things - Do they come with some sort of warranty, and would you take $430 for them?
How long were they "tested" for?
Were they only bought to see if your current packs were stuffed?
Oh, and will these fit, meaning are you able to put the Engine Center cover back on? (So it looks stock) Thanks.
Sorry about all of the questions.
Edited by The Mafia
https://www.sau.com.au/forums/topic/155656-sold/#findComment-2897009
Only warranty I can give you is that they work, if you buy them and I put them in your car they will work I can guarantee that . As with all elecronic parts you can stuff them up if you dont fit them correct, nobody will warranty that .
The price is $490 , no I wont take $430 , don't forget they are like new , if I didnt tell you they have been used you wouldn't know.
Very short period of time to rectify a fault on a car that turned out to be the CAS. ( not my car)
They are exacly the same as the stockers , so you can put the cover back on. Do you have a series II GTST? If yes they are suitable , If you have different car to your avatar then do a search to see if they are suitable using the part number in the pic. I know they are suitable for a series II GTST and R34 GTR.
https://www.sau.com.au/forums/topic/155656-sold/#findComment-2897464
And I am pretty sure that's even more warranty than you'll get from Splitfire themselves, because when I got mine a couple of years ago the documentation specifically said that the warranty is only valid in Japan. Unless they've changed their warranty policy recently. $490 is a bargain, I would buy them in an instant if I was after some.
https://www.sau.com.au/forums/topic/155656-sold/#findComment-2902318
Thanks for the comments jimX, i think they are well priced cionsidering they retail for $795.00 and they are almost new. If I can't get that I'll just keep them for spares for my car..
phatboi2010, They wont suit Rb20 mate, you will need DIS-001 for your car and GTRS up to series III R33.
These will suit RB25 from 95 on and RB26 R34 only.
https://www.sau.com.au/forums/topic/155656-sold/#findComment-2902417
PM sent
P.M send , please get back to me ASAP , the latest by tonight to confirm that you want them. If I don't hear from you by tonight they will be offered to the next person that wants them ..
https://www.sau.com.au/forums/topic/155656-sold/#findComment-2902826
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
