Please tell me what to modify and why i should modify it. Im looking for a decent amount of power around 300ish. doeas anyone know the 1/4 time and 0-60 with 300HP?.Help me out here guys!!!! teach me the ways and give me the knowledge :P
Edited by CalgaryGTS4
Hey mate, i have a friend with a gts4 and he got sick of the poor performance from the RB20, within two months he was buying a half cut of a GTR and fitting all the parts from that himself.. What a weapon it is now. A few simple mods to the RB26 gave 12.1 sec quater mile times.. But thats just my opinion, not everyone can afford that option...
How much would that run me Hp wise and Cash wise????
mate. instead of asking this. why not look through alot of the threads on here. believe it or not... in the last 5 years of these forums... 99.9% of the time someone else has gone through what u are going through now and has made a thread about it :P
Im unsure on what a front cut is worth these days $5000-up maybe.. High flow turbos 2nd hand, and EMS ECU, maybe $3000.. As for hp he makes 370rwhp on 14psi..
Ok well no offence the guys who tell him to go search the forums .. thats time consuming and a forum is here to ask questions, Yes might have been asked before but cant hurt twice..
Now seems you have a GTS4 R32 ?? Suppose your looking into engine mods depending what your doing ..
My first choices would be Twin dump, High flow 5" body cat, 3.5" exhaust 4" cannon, FMIC, (im assuming its a GTS-T?) and PowerFC if you can find one .. If not remap the stock ECU .. That should square you off at $3000ish.. Including installtions .. Powerfc or remap is essental and Id suggest the straight through exhaust too .. FMIC is optional but if your going to tweak your boosts id suggest it going into higher PSI
Hope it helps .. Ofcourse you'll want to look at gauges, Boost controller and get a really nice tune too!
Just for kicks after that Id hit up new Injectors, or used flow tested etc.. about 550's new fuel - pump bosch 080? Hit up a new turbo and boost it sky high .. again hoping its turbo .. concidering your avatar is a turbo id assume so
For the newbies we have this thing called "answers for things asked for the 100th time thread" aka > Stick Threads < :)
It pays to learn how to use the Search button properly...and yes there's even a thread on how to use it as well.
Just for kicks after that Id hit up new Injectors, or used flow tested etc.. about 550's new fuel pump bosch 040...
:P Edited by pkblade
hahah can u take out those abreviations on that mod list and tell me what they are hahah im kinda a noob still :)
FMIC = Front Mount Intercooler
ECU = Electronic Control Unit
Edited by pkblade
ok i see you have updated ur profile
r32 gts4
here my list
here we go
Aftermarket Ecu
-Apexi PowerFc $1000-$1500 (if you can find one)
Fuel Pump
-Nismo/Tomie $350
Injectors
-Nismo 740cc $800-$1000
AFM
-Z32 $300-$350
-Z32 Plug (can use an aus spec r31 afm plug, or buy the tomie one) $15-$30
Intercooler Kit
-Greddy M-spec $600-$800
-Greddy V-spl $1000-$1400
Turbo
-Stock Rb25 Turbo (from r33 or r34) $500
-HKS GT-SS $2000
there are just some examples,
NOTE: THIS DOES NOT INC LABOUR OR TUNING!
Tuning cost - $400-$600
Also Other mods i would consider!
Aftermarket Clutch
-$600-$2000 (depending on type, starting from the cheaper end Exedy Clutch, to then going to something like a hks or orc twin plate)
Coilovers
-Hks/Tein etc etc $1500 - $2000
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
