Just be careful that you dont touch the glass when you install it. Most of the time the oil of your fingers causes the light to reflect back into the globe and creates extra heat to cause it to blow and
Those cheap crappy xenon globes are crappy.
If you're planning on getting the Phillips blue globes and expecting them to be blue - don't. I've got a set in my car and they put out a nice white light, and they have noticeably improved visibility, but if you want blue, then they ain't got it :) Mind you, I don't think that's a bad thing :D
  • 3 weeks later...
The reason why oil from your fingers on globes causes them to fail early is because they form a heat sink on the quartz.
In a halogen light bulb, the tungsten filament gets so hot that some of it evaporates into the halogen. Normally the evaporated metal condenses back onto the filament again because of the halogen, within a couple of milliseconds.
When you get oil on the quartz (glass would melt because these bulbs run much hotter than normal bulbs), it draws heat away from the rest of the bulb, and the metal starts to condense on this cooler spot in the bulb instead despite the halogen.
Eventually you will then the bulb will fail in the exact same way as your house light bulbs fail. There will be a weak spot in the filament because too much has condensed onto the quartz.
This is also why you don't have to worry about touching normal vacuum type bulbs. With these, either way the filament will evaporate and condense onto the glass, and it doesn't matter if it does this in one spot or evenly over the inside.
Because of the way normal filament bulbs fail, in theory it shouldn't matter if you get oil on a HID bulb because they don't work by evaporation.
For anyone looking at upgrading their bulbs, have a look at Daniel Stern's Lighting page. This site has convinced me to get some Philips Vision Plus bulbs as my next car purchase.
  • 1 year later...
Revhead: Sorry to correct you but i've got a set of Phillips 5000k temp and they put out a v light-BLUE light. !, so blue i wish they were WHITE, so i only use them as my High beam for looks only but they set me back $100.
Seriously its BLUE but it isn't as bright as the normal ugly yellow
Usually the temp determines the colour of the light, if you get 4200, 4300k temp then they are yellowish/white, if you get 5000k they are blue, if you get 7500k they get purple, i hope this helps.
My set has lasted for over a year, and my headlight is cracked and letting in water where it fogs up but it still ok.
its not worth the money and visability is poor, thats all i can say about BLUE light from NON-HID head lights =(
I rang up autobarn to check the prices of phillips light globes,
the Phillips Diamond Vision 5000k H1 i've got in my car cost $145 from AUTOBARN!
in my opinion its not worth the money because only for LOOKS but poor for visability for that price you may as well get HID's for $450-500.
Guys guys guys....listen to me
This is gonna be the best advice ur ever gonna get.
Go to Kmart or whatnot and buy the autotechnica super white/blue globes. They are cheap as, like 10 bukcs or something.
Now i know ur all gonna say but they cant be good, it's autotechnica, they are gay. Yes they may be, but i have gone through alot of money buying phillips ones, and they kept fckn blowing. So i got these ones and i tell u what, they are brighter and whiter than any of the phillips ones. And they are still goin strong, havent blown for ages.
Trust me, just get a set and see what ya think. Ur gonna sauve urself shitloads of money but also get better light
I bought a set of osram silverstar globes. They arnt super white or anything, but they definately work much better than the normal halogens. You can definately see a bit further and tell that its brighter. Best thing is, it only cost me 40 bucks. May not have much bling factor, but when driving along with no streetlamps, you really come to appreciate them.
another thing to check is the voltage of your electrics while the car is running, esp. under a bit of load, if your alternator has a dodgy regulator the voltage could be spiking too high and that can kill bulbs.
Get a mutli-meter accross the ciggy lighter socket and take it for a burn, with a passenger keeping an eye on the reading, if you have fancy data-logging one you can do it by yourself. Just don't come back saying you crashed your car while looking at the meter rather than the road! :D
just a follow up about the phillips range of globes
like revhead and crooser say, the vision plus/blue vision, emit a white light, even tho the lens is slightly blue. they are probly equiv to a hella cool blue, altho slightly clearer.
i have crystal vision in mine (4300k colour temp def not a yellow/white light as gtshortie mentions, they are very white) and they work a treat, i think a good compromise between white and blue, altho not strictly legal.
also as gtshortie mentions, many ppl are disappointed with the diamond visions @ 5000k temp, they are blue enough to limit brightness and will attract some unwanted police attention.
as an auto electrician i replace the odd globe and recommend phillips, even the standard phillips, altho if u buying crystal or diamonds try and do some haggling, there is a substantial difference between retail and trade prices.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
