Hi Guys,
I've been a bit quiet caus of my shoulder reconstruction. (ouch!)
Went to Brisvegas yesterday, about a 100k. A few times I hit the O/D button in traffic tolessen the need
to brake.
I then noticed that when I backed off on the Freeway there was NO apparent engine braking nor any lossof revs, and the feel was sort of lumpy instead of smooth. Its an auto.
Later, maybe 10k, I noticed the 4Wd light on, the steering wheel covers it sonot sure how long it was on.
Still experiencing the "lumpy" drive feel. Got to Bris city and at a red light she cut out, but immediately restarted. The 4WD came on again.
Got to the Motel and parked for the night. Next morning no 4WD light. All systems AOK. Drove home, and all over today, noproblemo.
Any ideas???
Incidently, the Motel had one of those stacked car parks. I had 4mm clearance between the roof rails and
the upper deck. I took six attempts toget the Stag in, I even had to fold the RV mirrors in to make it fit, a guy in a Caprice in the next bay gave up and drove away. I wont be staying there again.
Edited by 66yostagea
https://www.sau.com.au/forums/topic/156207-4wd-light/
Lumpy feel... not just like when you are running it in constant AWD? (that little S button left of the steering column...), though that has nothing to do with why your 4wd light has come on??? - ...
I just know that my power button keeps staying on sometimes when i start up the car - completely random...
https://www.sau.com.au/forums/topic/156207-4wd-light/#findComment-2903087
Hugh, check the ATTESSA fluid, there is a small tankfor it in the boot, drivers side, behind the two little covers. Two bob nothing it's low, as I have had the same issue with the light because of that, but that does not explain the"lumpy" feeling though...........
https://www.sau.com.au/forums/topic/156207-4wd-light/#findComment-2903155
Yep. I'm in to that, level is fine.
The lumpy bit may not be the best description.
In a manual, when you back off, you get a positive braking effect from the engine. Right?
In an auto you get braking, but not to the samelevel of decelleration. But the decelleration is smooth.
When the light was on it felt sort of disjointed, and when accellerating again it felt like the torque converter was
either not picking up smoothly or the lock upmechanism was somehow malfunctioning.
When the light is on, does it mean a fault in the diffs, the transfer case or the tranny or theATTESSA?
I know by the "seat of the pants" something was off with the drive line. But which bit?
https://www.sau.com.au/forums/topic/156207-4wd-light/#findComment-2903442
get the attessa ecu out from behind the pasenger side rear fender panel area (note, its a pain in the arse to remove :laugh: ) and check the attessa diagnostic code as one of the sensors may be stuffed.
my 4wd light is on constant because i dont have the 2 wires from the ecu connected to tell the attessa ecu the rpm signal and tps signal.
https://www.sau.com.au/forums/topic/156207-4wd-light/#findComment-2903904
I know of two. From my testing experiences recently, having the TPS unplugged brings it on, and also pulling out the 4WD relay under bonnet brings it on.
Mine just cameon while driving. I had been using the O/D button to get a bit extra engine braking, about
half a dozen itmes only.
https://www.sau.com.au/forums/topic/156207-4wd-light/#findComment-2912823
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
