hey
I dont know if this video will help but im trying to find out if my timing belt is at the correct tension or its too tight. I dont want to have to retension it if its ok. A mechanic friend i know said its feels a little tight but isnt overly tight.
Cheers for any help
MOV01828.MPG
https://www.sau.com.au/forums/topic/156358-timing-belt-tension-with-video/
If you can do that, no way in the world is it overtight.
I always turn the engine clockwise to take the tension up and you have all the slack on the tensioner side of the belt, and you shouldn't be able to deflect it really much at all, unless you use fair force. (same as what should be done when you install it.
But nah, that wouldn't be too tight at all. IMHO
Edited by RB30-POWER
  • 1 year later...
  • 3 months later...
Sorry to bring back an old thread but after reading this I think I may have tensioned my belt incorrectly.
My question is....I havent technically started the motor since putting the belt on about 8-9 months ago....its probably done maybe 10 full rotations by hand since its been on.
Would this belt be ok to re tension do you think or should a new one be installed?
Cheers,
Ryan
you do not need a new belt unless its damaged from being way way to tight or way way to loose.
put the engine on no1 top dead centre, make sure the timing marks on the crank and cams all line up still.
crack the tensioner, tension belt as required, re-torque tensioner.
turn engine over twice and re-check belt tension is correct before putting it all back together.
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
