yep, its Austnet, channel is #skylinesaustralia
im on there all the time.
Yes I have seen you in there ;)
for those who dont know...
you can get mIRC >> HERE << (just right click and save as).
click on austnet in the server box, then type:
/join #skylinesaustralia
But that chat room eats up all your download time so I am not aloud to go in there anymore :sleep:
https://www.sau.com.au/forums/topic/156382-chat-room/#findComment-2907060
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
