  • Replies 508
  • 3 weeks later...
got the wheels on
fronts sit nice flush with the guard and rears could do with 10-15mm spacers to bring them flush (maybe more) and to be lowered lots.
chef- any updates with yours yet?
Edited by adam87
I have the elctrical diagrams for them now. should make debugging them a fair whack easier. I have one with a CAN issue currently and this is going to help immensly!
(FYI they are CAN bus driven car depsite how they appear as a 'simple box'. )
got the wheels on
Wheel and tyre specs, stat! Are they 205/40 17s?
My place looks like a wheel warehouse, got three sets of Rota RBs (16x7 +40s, Cube spec) and the Goocars for my car also arrived this week. They have tyres on them, but they're odd sizings, so I'm getting new rubber and sending it down to my local panel beater for the necessary guard massaging, then wheels/coilovers go on.
wheels are stitch precious at 17x7 +28 all round. rears could easily go to a +15 i think. and 205/40/17s for $160 for the set deilivered brand new :yes::)
chris rogers - how much to supply a cruise crontrol kit?
i looked over here but they seem pretty steep.
Edited by adam87
wheels are stitch precious at 17x7 +28 all round. rears could easily go to a +15 i think. and 205/40/17s for $160 for the set deilivered brand new :thanks::down:
what were you quoted? given that I'll put the controls on the right side of the wheel and its all DBW mine probably won't be as cheap as you are expecting.
for example:
thats one we did earlier.
This is 16x7 +35 front, +15 rear....
I'll take a few snaps of the ones david (cube cars) has. there is a black one with a decent stance on it and I think the wheel sizes are similar.
for example:
thats the picture i saw.
i think it was 60000yen ish plus install.
although i was going to do the install myself rather than pay someone over here to do it.
Edited by adam87
700 + 220 fitting. its not something you really want to attempt yourself. if you want a dash light on and a car that will start and not go anywhere - by all means have a go. :)
its a local product- made in brisbane actually. :) the yen has little to do with it. the criuse unit runs on the same base as the V35 items I do.
its a local product- made in brisbane actually. :blush: the yen has little to do with it. the criuse unit runs on the same base as the V35 items I do.
im in japan. the equivalent ones iv seen over here are a similar price then.
i was going to see if i could use the cheaper aussie dollar to my advantage :)
This is what a 17x8 +30 looks like...
Front will need some guard pulling - when we lowered it down, it was Mexican by about 25mm...
That's the rear - reckon it will only need a guard roll if I can find a camber kit soon enough...
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
