Hi all
Being dam hot here in Melbourne today (like 40 ) i had the aircon on and started to feel the air getting warmer. I pulled up at the lights and noticed steam. temp guage never got over half thank God.... :D
I was about 500 m from home . Soon as i got there (home) i looked under the bonnet and the steam was coming from behind the motor so i thought heater hose . turns out to be the little 1 under the heater hoses
I would have to say that its a utter bitch to get to..
Any 1 had this hose go ?
And whats the best way to get to it ?
Cheers
PS
OH yeah i have a R33 GTS-t with the Rb25
https://www.sau.com.au/forums/topic/156780-blown-small-hose/
from memory can you see if its just come off the nipple at the head area as if it has just move the coil wires out of the way and have a better look, if it has you may be able to push it back on and then clamp it back up, but yep pointy nose pliers never go astray on there
If you're talking about the same one as I am, it's not that hard.
Is it the water feed/return line for the turbo? How it wraps aroudn the back of the block and has a little bit of rubber hose on it?
If so, check otu the tutorial section. For the r32 turbo swap thread.
You probably won't be able to undo the 24mm banjo witht he oil line in the way, so i'd just removoe the oil line. that'll take 2 secs.
Then unbolt the 24mm banjo, reach around the block and undo the hose clamp. etc etc
Or maybe, you might be able to just change the hose without removing the water and oil line all together.
Just giving you two ways to do it if you get stuck one way or the other
i think he means the feed to the turbo and yeah it isn,t fun took me a while to get it on and i had every angle long nose pliers that exist, lots of swearing to get the hose on and then the clamp cause it sorta catches ont eh bend where it goes round the back of the block. good luck.
Cheers matt.
yeah, that's what I figured, so that's why I thought remove the water line,s o that you can replace the hose, and do the clamp up first without the line being in the way when the space is already tight. Then you can put the water line into the other end of the hose, and do that clamp up?
Well my day went from good to very bad..
I got up this morning and fixed the nose ..took a bit but got it done..
I took it for a test drive..(not good)
Had water gushing out of over flow like a preasure cleaner..Bla Bla Bla
At the end of the story i have done the Head Gasket
Hey man, don't mean to question you but are you sure that your head gasket is actually blown, if so can you tell me how you came to the conclusion? If you didn't bleed the system and you took it for a drive and your gauge went way up you may have done the head gasket but it still may be ok.
let me know.
Cheers Matt.
let me know.
Cheers Matt.
I would love to think it wasnt the gasket......but
the water has gone from a nice green to a light brown thick oil based
and when i tried adding water at the service station it kept blowing back at me
and trying to get home i didnt put the cap on tight.. But it still built up enough preasue to blow
the top radiator hose to bits..
bad luck mate ;)
same hose i'm pissed off about right now, finished my rb25/30 conversion last week and discovered that this hose is on the verge of busting (spraying out at higher temps).. it's twice as fun to get to when you have the added height of the 30 block >_< then you've got to deal with the brake lines being in the way and all sorts of other fun stuff :laugh:
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
