you will need to trim the snorkel a bit for it to fit.
as for cutting the reo.. you can always sit the front mount further back but you probably wouldnt be using any 'off the shelf' piping kits as most are designed for the front mount to bolt up to the reo bar.
  • Replies 56
  • 2 months later...
Sorry to hijack the thread but does anybody have any pics of where their intercooler pipe comes through on the drivers side and over the top of the fan blades or wherever it goes???
Anyone that has installed these lately can you please let me know about the Inlet pipe to the intercooler. It is longer on one side than the other by about 3-5cm.
Does the longer piece connect to the old pipe coming through the hole in the chassis or does it connect to the intercooler inlet?
It seems that either would way might work..
You can cut them after the piping is fitted and the fan still on. Its probably better to do so, so you can check how much needs to be lopped off and check the clearance. As for cutting, we used a pneumatic die grinder with the cutting disc attachment. Or alternatively you could use some tin snips.
We spun the blade around and held a marker in one spot to evenly mark the blades.
Edited by KeyMakeR33
I gave you photo's of where the hole goes in you other thread.
http://www.skylinesaustralia.com/forums/in...20&start=20
Does anyone Know where to get a smaller type intercooler. I mean thinner like 50mm or something. That might suit this guys application better. I am trying to do the same thing too, i might go for a thinner cooler and try get something that has both outlets on the same side so that I can connect it back up to the factory piping.
Anyone know of places that sell thinner coolers and ones that have outlets on the same side.
Also i am not chasing any big HP figures so i think a thinner cooler might just do me nicely.
Just jap have a cooler that has outlets on the same side. I don't think its any thinner though and you would have to get some piping made for you.
Oh yeah i know but i mean does anybody have any pics with the pipes in place??
Cheers.
:D
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
