RELISTED DUE TO SALE FALLING THROUGH!!!
Item:
Unknown brand sports steering wheel with boss kit.
Brisbane / will post
Item Condition:
Very good execpt that plastic shroud for boss kit was spilt (pictured) and taken off during the removal of the steering wheel.
Reason for Selling:
Came with the car when i brought it, don't like the style of it so stock wheel is back on the car.
Price and Payment Conditions:
$50 + extra for postage if required
Extra Info:
Contains all the hardware need for the horn to work with the boss kit. Just bolt it on and your away. Came off a Nissan 300zx so check to make sure that it will fit your car please.
Contact Details:
PM, email [email protected] or Mob 0401840770
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
