Thats right he is committing the biggest sin known to the male kind, he's getting married :spank:
Congrats mate, i hope it all goes well on Satruday for you and the little lady and wish you all the best for a happy future together :rofl:
Oh and make sure you let me know if there are any nice single females that need an escort wont you.
Im more than happy to help out :O
GMB
https://www.sau.com.au/forums/topic/157352-rip-benno/
Thats right he is committing the biggest sin known to the male kind, he's getting married :huh:
Congrats mate, i hope it all goes well on Satruday for you and the little lady and wish you all the best for a happy future together :laugh:
Im more than happy to help out :laugh:
GMB
Holly shit Ben, When I read R.I.P, I thought WTF.
All the Best Stu.
https://www.sau.com.au/forums/topic/157352-rip-benno/#findComment-2923691
So today is the day of the execution, any last requests :happy:
All the best mate to you and the little lady, will have to catch up for a drink when Targa is over and things have quietened down a little :(
GMB
https://www.sau.com.au/forums/topic/157352-rip-benno/#findComment-2930900
All run and done and I'm still kicking - thanks again guys.
The fleet of WRX wedding cars probaly wasn't in the best Nissan taste!
Well i had ALMOST forgiven you for buying a rotisary but now you have the nerve to say you used WRX's as your wedding cars...
What were you thinking Benno :D:P
I move for :P
:D
https://www.sau.com.au/forums/topic/157352-rip-benno/#findComment-2933748
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
