hey again
wanna run my car down the 1/4 as i have previously stated but i want to be realistic and run with my street tyres.. i got 18 in rims on it now and wanna know what tyre to go for... either a 255/35/18 or 245/40/18?
a friend told me to go for the 245's cause of its higher profile.
i have no clue..
https://www.sau.com.au/forums/topic/157365-2553518-vs-2454018s-for-the-14/
You will probably get a faster time with smaller inch rims..
Im no expert either..
but i remember when i was at the drags, a guy from this forums put his stockies on and got a much better time than his 18 inch rims lol...
Anyways i dont think you will find some difference between them.. It will come down to your launch, and how well the rubbers grip..
Do the 255s, have better rubber than 245s??
im not too sure but a friend who works with tyres told me that the 40 profile is better for the strip
the larger profile will give you more grip as the side wall will have a bit more flex so in s triaght line you the tire wont spin up as easily, i would also lower your tire pressure to give you a geater contact area with the road
have fun at the drags
I'd say there would not be much in it running the 18s.
The 255 gives you up to 10mm more width. I say up to as a tyres width rating is a maximum width allowed meaning it could in fact be smaller. Wheels or Motor mag did a tyre comparo a while ago with a variety of 245 wide 17s and only one make of tyre (the cheapest) actually measured up to 245 wide, the rest were all narower.
The 245 tyre will give you around 9mm more sidewall which is ideal for drag but make your overall diameter 18mm taller.
I guess if one had to be chosen it would be the 245 but thats assuming both tyres are the same make etc.
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
