Well hard springs stop roll, but they also stop everything else from working properly. The shock controls the spring, so thats the tricky (and expencive) bit... If you have hard springs you cant make a shock to control the spring properly.
So if you want to stop roll, get big anti roll bars. I have a solid 30mm on the front of my cef, and I really think its over kill, I feel sometimes the front is just too solid. So I would just go the whiteline stuff.
If what people keep going on about with drift, the best set up should be a proper track set up (as in to have as much grip as posible) just with stiffer antisway bars with a bias to the rear. That way the car is going to handle as best it can, and be the most balanced and predictable.
But most of the drifters run really low, and stupid stiff springs.
  • Replies 67
Posted Images
So like wat salad said is get custom rate spring and wat is the best rate ? Lots of Japs using 8 in the front and 6 in the back. How about Cusco adjustable sway bar cause i have them in my garage. Will S13 sway bar fit on the R32 4 Door ? Also wat is "BIAS" ? is the pineapple really help a lot ?
If i want the good Suspension setup do i get whole suspension package like front top n bottom arms adjustable , castor rods, tie rods , tie rod ends, tie rod spacer and etc ?
Thank u very much for the advice mate.
^^^ Agreed EDIT: agreeing with dangerous_daveo, most drifters just follow what ever the japs do and think its sick. And most are cheap as anything so just get the cheapest coilovers they can cos lets face it, coilovers are coilovers aren't they? :)
Edited by salad
silkroad section spec rma8 coilovers
gtr sway bars
cusco bracing
section/ikeya formula/kazama adjustable bits
exhaust technology exhaust
wonder kit (will be going to origin when i destroy this)
gtr sway bars
cusco bracing
can u tell me wat is ur suspension like ? are they jap brand ?
Thanks
Mick
I'm using Bilstein B6 shocks, converted to coilovers with Eibach springs. Rears have a better piston than the B6 though
wat u mean by better piston in the rear are they B6 as well ? How do u converted to coilovers custom or the Bilsteins design for coilovers ?
i've got the ISC's with 10kg front springs (damper on 16/32) and 8kg rear springs (damper on 18/32) - also whiteline 27mm blade adjustable front swaybar set to medium and 22mm blade adjustable rear swaybar set to hard.
i have no understeer - but front tyres - falken azenis rt215 - 215/45/17 on 8" rim does help.
i am going to try a softer rear spring ( 6kg) to test to gain more grip
**also adjustable rear camber arms and toe arms are already in use.
also look at getting a rear subframe alignment kit, sk recomended that to me and so far i really like it. It takes the sloppy ness out of the rear end, ...i will let u know how it feels on the track after sat.
oh and huddy what length endlinks do u have on the front swaybar? ...55mm centre of bolt hole to centre of bolt hole? are u able to get it on the hardest setting? ......i just got 75mm ones which now allow this .....quite a bit different.
Edited by Resin
silkroad section rma8 are japanese yes
google for reviews on them... widely popular in japan, usa and hawaii...
several well known professional drifters in aus use these also or have used these
The rear shocks came out of a race car, I'm not too sure what piston they are. When I bought them I thought they were just the normal piston, guy told me after that they were a better piston.
The Bilsteins usually have a normal spring seat that sits on a circlip in a groove. To convert to coilovers Bilstein sell a kit that includes a threaded sleeve (that sits on the circlip groove instead), lower spring seat, locking ring and upper spring seat adapter to use with standard strut tops.
i cannot remember exactly - but i think i did test to check that - and i think i did have 0 problems keeping the endlinks vertical. re-installing new cradle tomorrow so if i remember i will check again :O
Why the new cradle Huddy?
Also, before you chuck the new one in, weld up the lower control arm mounts, apparently they break off a fair bit with track use and high grip tyres.
Wouldn't be surprised as mine broke with just Antyres....
Edited by salad
Which is what I have. I'll grab some photos tomorrow.
But the best bang for buck (as in spending less than $8-10k which would be a semi race shock...) is the Sydney Kid suspension group buy, which is listed in the group buy section in the for-sale forums.
And what I mean by playing with the 'bias' of the sway bars is just making them harder or softer to suit. Say drift you might want the rear a bit harder so the rear kicks out easier.
anyone ever heard/used ZEAL coilovers?
very interesting replies in this topic, ill be watching this :(
Yes mate...I use them in the laurel. Great coilover :)
Suspension:
Zeal Function B6 coilovers, Cusco castor rods, D-Project Rear camber, toe and traction arms, Whiteline 27/24mm swaybars, alloy subframe bushes
Exhaust:
Gp Sports 3" straight thru exhaust, 3" front/dump pipe.
Body:
Original front and rear bars, unknown sideskirts
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
