  • Replies 171
whats happened to all the people who said theyd be in the NSW Members Thread?
Again come on guys.... try something different, this will be my first time at drifting and the good thing is you wont be worrying about hitting pedestrians/gutteres/power poles.
Stephen,
re: all the guys who posted in nsw members thread - I sent about 95% of those members a PM, and they either had no money or the car was off the road, or didnt reply....
:happy:
ahh man..... sucks... how convinient for it to be during this time
i think this day will go well apart from the numbers gotta get the skyline presence strong in all types of motorsports.
oh yeah... saw the vid of ur clover drift.... very nice...u gotta give me some pointers on the day
I have attended a similar drift practice day once before and can vouch that it is a stack of fun in a safe environment. Where else do you get do do massive power slides and smoke up a good set of tyres? Even on track days you are not allowed to drive like this. Not only is it fun but it is a great learning experience.
chris do u have a linked vid of the clover leaf skid pan??i want to see. :laugh:
changed the engine (castrol edge sport) & gearbox oil (penrite 10 tenths).and also fuel filter.just waiting for the shim to arrive so i can pull diff and do the oil...
Im rolling no front bar come drift day.i try to steer clear of leaving the track souvenir's as they cost to much and i dont want the tourists going home with the koalas.
ok thats it,,,
im definately in! will transfer money tomorrow, send off membership forms for sau and cams licence...
car is almost sorted but should have it sorted and on the dyno before the day......
Add me officially to the list :) Definately not missing it!
got a whole set of 32 rims and 33 rims half with tyres, off to the tyre shop to get some more crapola tyres...
im wondering if i should go all out and get swaybars fitted before the day? my coilovers are pretty stiff so dunno if ill bother...hmmmm
I'll be drifting on standard Nissan suspension, so I'm sure your set up will be great with or without the sway bars.
ill just crank the back down for some more neg camber, and better roll centre hahahaha
stock suspension goes hard drifting!
ive got some 2yo rubber that should smoke good! and hopefully a mate bringing a suby wagon down i can load up with all my shit....
even better
adam, ill send that membership form off tonight, transfer the money and do cams registration tomorrow morning... its all coming together....
nice!
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
