hey sau.
ok i wouldnt normally post such a noobie question but its been egging at me for a while. so
What is the standard boost for a R32 GTR?
what boost am i running according to this gauge.?
(best pic i could get when on boost)
and how do u read the standard gauge?
thanks
mark.
https://www.sau.com.au/forums/topic/157595-r32-gtr-questions/
hey sau.
thanks
mark.
Hmmm
the std GTR gauge reads in mm of mercury (no idea why?)
my understanding is that if you hit the 7, that's about 1 bar = ~15psi
by the look of this you are a little under that (~12psi) - is that what you get with the restrictor removed ?
std boost on a GTR is about 7-9 psi - right ?
ok so going from my pic wrx hoon im on around 10psi?
Yes it looks to me about 500 ( 350 is the first line and 700 the last ). You can never take the stock gauge fro granted though , get a proper boost gauge.
GTR can take 14psi right..? thats standards.. wat can N1 items take?
Standard GTR turbos will make more than 14psi ( no worries there ) , the problem is how long for . It wont be long before the exhaust wheel flies off and maybe your engine with it .
N1's , depends on which N1's , there are so many different ones , I had no problem holding 1.4 bar all the way to 8k rpm with the Nismo GT N1's in a R33 GTR with a built engine .
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
