Hey guys
I have a toshiba satellite notebook with windows xp pent 2, clean reformated hd. Only thing i bought it for and have used it for so far has been the Nissan Datascan v1.51
Fun toy to use.
So this sale comes with the laptop and software already installed, plus the software on a cd. Also comes with a usb cable that has a plug which will fit directly onto the plug coming from the ecu next to your fuses. Also comes with battery,power cables and carry bag
price is $250 pickup only
eastern sub melb
Available functions:
1. ECU Part Number
* Nissan Identification part number
2. Data Display
* Resizable window
* Analogue and digital gauges
* Peak value display
Parameters depending on ECU:
* RPM
* Air Flow
* Air Flow Right Hand
* Water Temperature (C or F)
* O2 Sensor
* O2 Sensor Right Hand
* Speed (KPH or MPH) with tyre size correction
* Battery Voltage
* Throttle Position Sensor
* Fuel Temperature (C or F)
* Intake Air Temperature (C or F)
* Exhaust Gas Temperature
* Injector Time
* Ignition Timing
* AAC Valve
* Air Fuel Base
* Air Fuel Base Right Hand
* Air Fuel Base Self Learn
* Air Fuel Base Self Learn Right Hand
* Injector Time Right Hand
* Duty Cycle
* Duty Cycle RH
* O2 Sensor B1
* O2 Sensor B2
Registers:
* Closed TPS
* Power Steering
* Air Conditioning Switch
* Start Signal
* Neutral
* Air Conditioning Relay
* Fuel Pump
* Thermo Fan
* VCT
* Waste Gate Solenoid
* Air/Fuel ratio (lean/rich)
* EGR Solenoid
3. Data Logging
Parameters and registers as per Data Display
4. Active Test
* Engine Temperature
* Timing
* AAC Valve
* IACV Valve
* Air/Fuel Base
* VCT
* Fuel Pump
* Cylinder Off
* Base Idle Adjustment
* clear Self Learn
5. Self Diagnostics
* Read Fault Codes
* Reset Fault Codes
6. Speed Trial
Measured times (kph or mph):
* 0-60
* 0-100
* 50-100
* 0-xx
* xx-xx
7. Rom Data
* Slow Data Download (1 byte at the time)
* Fast Data Download (8 bytes at the time)
8. Address Watch
* Any address in CPU memory
9. Active register test
* Discovers parameters supported by the ECU
10. Map trace
* A real time trace of a position on the map. This function is only available for z32 300zx cars at the moment. If the real time TP value address is known the function can be set up to work on any Consult I Nissan car.
11. Data Replay
* Replays previously logged file
* Adjustable replay speed, fast forward and rewind
* Resizable window
12. Data log Analyser
* 2 graph windows
* User selectable parameters
* Digital value display
* Not recommended for large files
13. Dashboard
* 2 large gauge display
* Speed and RPM alert
super bargin! cable alone worth $100, datascan $25 and laptop $250
if i didn't already have all this i would take it for sure :)
how decent is the lap top?
im really interested i live in sydney thou, but proberly can get some one to pick it up
Edited by (oo\__4Door__/oo)
It's not a super good laptop, but will run the program fine and other programs fine. Don't buy it thinking your getting the latest hitech laptop though
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
