Bought a cheap aussia standard approved bash hat for the upcoming test n tune days and thought i might play along with the general theme of the geriatric wheelchair bound old codger some of the puppies have tagged me with. Dont know if any of you are old enuff to remember but there used to be a sticker around depicting a crazy old coot in a v8 wheelchair with his eyes bulgin out doin a burnout.
Asked an airbrush artist what it would cost to have it airbrushed on the hat and just fell on my arse when he told me.
Any body care to take a guess at the figure? :)
https://www.sau.com.au/forums/topic/157740-airbrush-art/
Any body care to take a guess at the figure? :D
how much for ur helmet noel? i want one too.. :( wanna pay as little as possible and not pick up some dead ex bikey helmet.. dnt care for looks just something i could use once a year or so.. :wave:
https://www.sau.com.au/forums/topic/157740-airbrush-art/#findComment-2930488
how much for ur helmet noel? i want one too.. :( wanna pay as little as possible and not pick up some dead ex bikey helmet.. dnt care for looks just something i could use once a year or so.. :happy:
Just go to ya local bike shop bloke. cheap as chips.
https://www.sau.com.au/forums/topic/157740-airbrush-art/#findComment-2930651
I will draw you a pics for free on the helmet...all I need is a white out pen
Here is a sample of my awesome work
So its not "errmmm pssst" like the HKS apron your airbrushed for marc?
That was pure gold btw bunta.. made him cook faster with an extra 10Sw's of POWA
https://www.sau.com.au/forums/topic/157740-airbrush-art/#findComment-2941224
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
