Thanks for the info Steve, there's some good stuff there.
I got the error codes out of the ECU, and it got an error 13, which is apparently a Coolant Temp Sensor error. Does anyone know if this is referring to the sensor near the block, just near the pressure reg, or the one on the radiator? i suspect the one near the block is for the ECU, and the one on the radiator just runs the gauge, does that sound right?
And should this error stop the ECU from starting the engine, or is it something it should be able to ignore? (i'm going to fix the sensor anyway)
Another thought i had is that maybe i need to connect the neutral switch from the (manual) gearbox up, which i haven't done yet. would this be affecting it as well?
Thanks again for any help guys,
Adam.
https://www.sau.com.au/forums/topic/15777-rb20det-conversion-wont-start/
Thge ECUtemp sender and the gauge temp sender are next to each other on the pipe returning to the top radiator. The ECU sender has a yellow plug. The sender in the radiator is a switch for the A/C thermatic fan.
The fact that the ECU sender has a fault shouldn't stop the engine from starting.
What you have done (pull a coil/plug) is the simplest way to test for spark. Its likely the igniter module (on the top of the engine at the back) is faulty. See if you can get hold of another one.
see if you can clear the error (ECU reset). Often, something silly like disconnect the connector on the sender while engine running will trigger the fault code.
Clear the code, then if it reoccurs, its likely the sender is faulty.
I have a sneaking suspicion i may have killed some of the wiring in that area, damn nissan engineers. There are two wires in the ecu loom that are identically marked (black, red trace, silver spot) and the same gauge, sitting right next to each other. One of them is the IGN +12v line for the ecu, the other is some random ground line. So of course first time round, i spliced 12v into the wrong one didn't i?, turned the igntion on to see if i had 12v at the ecu connector (thankfully without the ecu plugged in, and all i got was a very warm, slightly melted ground line : ( I was hoping that it might have just melted the insulation off the wire, and that the core and surrounding wires were ok, but it seems now that i've killed the sender wire. The sender itself seems ok, reads 2.2k, which is better than open or closed i guess. hopefully it's just the wire, and hopefully just that one. But it does mean i have to pull the loom out from the intake manifold, unwrap the whole thing, check the wires and re wrap it all.
Oh well, i guess it might be a good chance to pull the injectors out and see if they're working.
well after a weekend spent troubleshooting the various components, unwrapping the entire loom, replacing the wire i melted, putting the loom back together, removing the fuel rail (without removing the manifold!) testing the injectors, unblocking 2 of them, cleaning up all the ground points, and lots of head scratching, i finally got the thing going.
I hadn't killed anything, which was a relief, but in the end it turned out that i didn't have 12v to the coils (which i should have checked ages ago of course...) because the coils get there 12v feed from a different point to the rest of the loom. I piece of wire, and 1 spade terminal later, the car fired immediately, after only cranking for like 1 second. So now after 18 months my nicely rebuilt RB20DET is finally running. I am the happiest guy in the world at the moment : ).
Now i just have to get the rest of the car roadworthy....
Thanks heaps to all the guys who offered assistance and advice, it was all helpfull and much appreciated.
Cheers,
Adam
Great to hear it all finally paid off. If you get the chance, post some pics up - always nice to see a unique project come together. Perhaps even a few words on what to watch out for, just incase there is anybody else out there planning a similar engine upgrade.:D
Cheers
Steve
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
