Annual Sau Dyno Day Pictures/video And Discussion
Hey guys thought i would start a thread for all the pictures.
Great Day, Nice people.. VERY Burnt :)
post-31661-1172294407.jpgpost-31661-1172294471.jpgpost-31661-1172294507.jpgpost-31661-1172294576.jpgpost-31661-1172294611.jpgpost-17508-1129956235.jpgpost-31661-1172294662.jpgpost-31661-1172294738.jpg[attachmen
=84495:attachment]post-31661-1172294984.jpgpost-31661-1172295018.jpg[att
chment=84498:attachment]post-31661-1172295121.jpgpost-31661-1172295173.jpgpost-31661-1172295275.jpgpost-31661-1172295365.jpgpost-31661-1172295399.jpgpost-31661-1172295450.jpgpost-31661-1172295483.jpgpost-11183-1123575350.jpgpost-31661-1172295557.jpgpost-31661-1172296742.jpg[attachme
t=84509:attachment]post-31661-1172296810.jpgpost-31661-1172296893.jpg[at
achment=84512:attachment]post-31661-1172296991.jpgpost-31661-1172295483.jpgpost-31661-1172295516.jpgpost-31661-1172297169.jpgpost-31661-1172297212.jpgpost-31661-1172297258.jpgpost-31661-1172297484.jpgpost-5552-1123040788.jpgpost-31661-1172297627.jpgpost-31661-1172297673.jpg[attachm
nt=84527:attachment]post-31661-1172297791.jpgpost-31661-1172297831.jpg[a
tachment=84530:attachment]post-31661-1172297913.jpgpost-31661-1172297969.jpgpost-31661-1172298022.jpgpost-31661-1172298071.jpgpost-31661-1172298110.jpg
Edited by R32-PSH77
  • Replies 140
nice pics adam.. great time met a few new faces.. shame i only got 139rwkw :D..
Huge Thanks to COL !!! thanks for moving me up when i needed to head off..
Anna and the rest of the crew will explain the GTR Boot story
Edited by 53XYN
I'm stuffed. what a great day. Hats off to those poor buggas doin all the work, they just never stopped.
The bionic wheelchair went off the scale at a massive 178 kws. Stoked.
Saw some drop dead gorgeous lines and met some more liners. Luvit. :D
Thats ok Vish, a few stock GTTs have made around tht power especially the tiptronics. Were u running stock boost? Mine only had 147rwkws on the same dyno at the last dyno day with only an apexi catback...so ur not far off the mark.
Noel: that is bloody awesome! :sorcerer:
Was good to meet up with some of the people from this club.
Pretty happy with my 187rwkw considering close to stock. Thanks for the pic of my car, paid off giving it a wash this morning.
look foward to meeting a few more of you.
cheers :D
Edited by Spooner
I have merged all the topics into this one topic;
Please use this thread to discuss the event and post your images/video...
All results will be up shortlly...
Thank You
In the mean time;
(All results are in rwkw)
1. 150
2. 218
3. 101
4. 70
5. 215
6. 339
7. 187
8. 147
9. 139
10. 185
11. 231
12. 170
13. 126
14. 181
15. 301
16. 156
17. 220
18. 123
19. 232
20. 94
21. Could not get it up :D
22. 243
23. DNR
24. 129
25. 194
26. 143
27. 139
28. 249
29. 221
30. 95
31. 64
32. 146
33. 198
34. 178
35. 203
36. 209
37. 201
Can I also pre-warn you all. A full explaination as to ramp rate and how a dyno logic dyno works will be posted up once i get the chance. Please dont jump on the band wagon about how high ro low this dyno reads. As this dyno was serviced and benchmarked only 8 days ago. So please dont jump onto the band wagon about the figures until you understand all factors involved in giving a reading.
In the mean time feel free to discuss the matter...
sweet as....not bad hey for a 26. Well i was stuck at home re-fabricating new i/c piping to hopefully fix our boost leak instead of enjoying the action. Man if our car was sorted out, could have taken out 1st..somewhere between 370-400rwkw.
Unless the figures you are quoting were from this same dyno you may have been disapointed too. :D
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
