That you Zubin?? If so, HELLO!!! :)
I had G-grids on my previous car, and I loved them! (but that was a Laser and a whole different story LOL)
If your Falken's are crap, why not try the the G-grids? If they're just sitting there (and if you can't afford 901's) then it can't hurt!!
https://www.sau.com.au/forums/topic/158-which-tyre/#findComment-4096
OK... the reason why i say my Falkens are crap (NOTE not ALL Falken) is because:
a) I understeer 8O in the wet around corners at any moderate speed
B) traction is completely non-existant in the wet. :lol:
c) when giving it some, the transition from 1st to 2nd (in the dry) makes the back step out heaps. And my car is STOCK.
In the past 20,000 k's they dont seem to have worn at all, so i guess thats an ok thing. What pressure do you guys run.... i found that @ approx 36psi (warm) i got better grip than @ 30-32psi.
I will see if i can change to the g-grid II's and see what change there is...
https://www.sau.com.au/forums/topic/158-which-tyre/#findComment-4108
I got a set of FM901s a few weeks ago from Mathews Tyres Chatswood
235/45 17
255/40 17
$1010 plus ~$30 for some super duper balance job....
They are noisier (road rumble) than the pirelli/michelin combo I had on but grip seems pretty good. I had one delaminate at Wakefield when they were 5 days and ~400 km old. It had a groovy beat to it while I limped back to the pits... :lol:
Mathews were not very helpful at first but after some "discussion" they got on to Dunlop and found a place in Goulburn to look after me.
Took the stuffed tyre to Beaurepaires Brookvale and they had a new one for me next day no charge.
https://www.sau.com.au/forums/topic/158-which-tyre/#findComment-4111
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
