yes steering IS speed sensitive (is in a GTR anyway, i assume its the same across 32s)
and the signal comes from back of speedo guage
very strange setup, speedo is cable from gearbox to guage, then changed to electric from back of guage to whereever needed
Hope This Helps
RellikZephyr
https://www.sau.com.au/forums/topic/158146-r32/#findComment-2936624
anyone know where the wire that tells the rack to go into hi ppessure mode comes from
it much start at certin speed
when first did neo conversion steering very heavy
so put 12 v wire onto rack switch
works well at low speeds but doesint turn off at high speeds
very touchy to drive
https://www.sau.com.au/forums/topic/158146-r32/#findComment-2937432
There is a control unit in the boot (under the parcel shelf) for the HICAS, is this still plugged in? I think if it's not you get heavy steering all the time, also if you lose the signal from the speedo it will get heavy. I think what you've done is bypass the the control unit and feed a constant 12v to the rack all the time, it's obviously not going to vary itself.
https://www.sau.com.au/forums/topic/158146-r32/#findComment-2952259
cheers for the reply
where soes the wire come from
it must come out of the dash loom
yes i was only getting heavy power steer
witch it cool if u go fast everywhere but defently not turned off
turns out high pressue low pressure switch so
yes we applied 12 v constant to the high pressue low pressure switch
ime thinking it comes through the engin bay loom witch i now no longer have so it must plug in on the dash conector behind the kick panel
but witch wire is it
anyone got dash conector pinout maybee that would be a start
thanks in advance guys
https://www.sau.com.au/forums/topic/158146-r32/#findComment-2961886
  • 5 weeks later...
how did you go mate? did the power steering become heavy right away, or come on after driving a couple mins
https://www.sau.com.au/forums/topic/158146-r32/#findComment-3034528
If you've put constant power onto the rack, of course it won't turn off at any speed..
ok, ill be nice now.
Wire colours are black, and black/yellow stripe. 2 pin connector going into engine harness 2, and another 2 pin connector same wire colours going onto the solenoid connector.
these 2 wires, black is grouped in the main engine harness connected to body ground, black/yellow goes to the body harness connector and other side of that connetor to the hicas module.
Edited by heller44
https://www.sau.com.au/forums/topic/158146-r32/#findComment-3056178
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
