Has anybody mucked around with the hi-clone. We were debating its use on a turbocharged car the other day and it got me thinking...
So, anybody played with one on the RB25? Neo? Fuel ecconomy numbers or dyno results?
:action-smiley-069::banana:
dont go there they are crap, if you want info on them check austalian 4wd forums they tell you the same thing.... crap
https://www.sau.com.au/forums/topic/158272-hi-clones/#findComment-2938254
^^ What he said - I put one on a mates turbo diesel 'cruiser a few years ago and it made exactly NO difference. We were really glad he won it in a 4WD gymkhana (which is a crapload of fun BTW) because if he had to pay for it he would have been annoyed at the complete and utter waste of money.
https://www.sau.com.au/forums/topic/158272-hi-clones/#findComment-2938285
Is this the crap that you put along the fuel line to give you magical boost?
its a flash little bit of specially shaped tin that you put in the air inlet that is supposed to "create a vortex to present an ordered, denser airflow"
I have never actually met anyone that has said they used it and were impressed.
Edited by newbie101
https://www.sau.com.au/forums/topic/158272-hi-clones/#findComment-2938311
I thought it worked on the principal that a vortex had faster air flow........... try it on a big glass bottle, fill it up with water and hold it upside down and let it flow out and time it, then do the same but spin it a bit so the water spins out, you'll find it is exactly the same or a bit more as you spend a second or two spinning it to work the vortex up...........
https://www.sau.com.au/forums/topic/158272-hi-clones/#findComment-2938346
I would just like to add that this wasn't my question, nor did I start this thread. Looks like someone was using my computer while I was in a meeting until 2.45pm.
I had already come to the same conclusion as the rest of you...but then again it would be interesting to see some hard facts and figures from a dyno run...just not sure if anybody would be prepared to waste the money.
I would just like to take this opportunity to apologise to anybody who may have thought I would be sacreligous enough to even think about installing one of these units on the Stagea
https://www.sau.com.au/forums/topic/158272-hi-clones/#findComment-2939717
I saw a VL turbo on the dyno about 4 years ago, stock setup with a 2.5inch exhaust. The owner was sure that the device made more power. After heaps of us bugging him about it, he put it on the dyno. The deal was this: if it made more power WITH the device fitted, we all chipped in and bought him some beer and paid for the dyno session, it he lost power, he paid.
After just over 2 hours on the dyno, well, we got the beer! I'm no beer drinker, but it was interesting to see the power difference! In 5th gear at 110km/h, the device lost 2hp! we did a few runs, but the average was 2hp. the operator ramped it up, then down. The dyno operator made a comment that the fuel numbers were changing, only slightly, but changing just the same! The VL owner was chutching at straws and asked about an outright power pull.
We all agreed, we figured we had nothing to loose! the humble old VL made a duplicate shaped power curve, but it was all to the right. it lost peak power by 7-9 hp.
The arugment was settled.. but the owner of the VL stated that he MAY not have the Hi-clone in the corect place.. bla bla bla.. I have yet to see ANY car MAKE power with this device!
I wish i got a print out of that day. But rest easy, save your $$ for a real mod!
any conflicting evidence? :(
https://www.sau.com.au/forums/topic/158272-hi-clones/#findComment-2942616
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
