I have retarded the timing on my RB20 by exhaust cam by 4deg running 19psi with a slide hiflow and have noticed the difference right away.
Firstly the A/F ratio went from a flat 12:1 to a bell curve starting at 12:1 at 3400 and leaning out to 12.6:1 at 5000 and then settling back down to 12:1 at 7000. I used a tech edge with data logging to measure this.
I have reset the base timing to 15deg as it actually dropped 3 deg after retarding the cam timing.
The car is now coming on boost slightly quicker and hits full bost around 200-400 rpm quicker depending on the gear and the midrange FEELS more responsive. peak power feels the same but it gets there quicker so the whole package feels faster.
I added fuel to compensate and bring the AFR's back to a safer level and keep it to 12:1 as close as possible.
I have not touched the timing map as there is no detection of knock. I use a modified condenser microphone connected to a laptop recording in real time and can be referenced to the rpm scale of datascan.
so all in all looks like quite a decent gain. seat of the pants tells me there is no more power just power earlier in the rev range and let's face it all RB20's need earlier power delivery.
without tune yes there was more response but it was leaning out. so i have already added fuel and there is more response but no more peak power.
I am only speculating as i have not had it on a dyno. but it comes on boost faster yes :no:
there would still be gains to be had even form a stock turbo. the amount of overlap Nissan designed was a compromise between response and power and emissions. with the amount of overlap they run stock you get a longer cleaner burn but less power.
so you may gain some midrange power with a stock turbo but there would be cheaper ways of getting the same performance increase from a relatively standard car.
You can buy one of the arospeed cam gears for $70 but a mechanic would charge you $200 to install it and you will need to pay for atleast an hour of dyno time to get a confirmed result. so it would end up costing you almost $400.
For that amount you could buy and install
front+dump pipe, FMIC, SAFC or a boost controller. all of these will give you good gains. the cam gear is really something you would do after the more common mods.
very worth while if you have already done the basics.
After going for a nice long drive lastnight i can say boost comes on just that bit earlier and makes a big difference in how the car behaves.
sweeeeet.
getting my aerospeed exhaust cam gear installed, exhaust manifold studs replaced, gaskets replaced, and dyno tune with the FPR, Z32 afm, SITC, SAFCii and the Slide highflow. Got the fuel pump, the intake and exhaust is full sorted. Should be good ! :D
under $700 too
is it worthwhile adding adj camgears to an engine with stock turbo (to tweak power delivery rather than for outright power gains)?
or should you only consider this if you've upgraded your turbo too?
In previous threads some people have had no gains by retarding the ex cam on a fairly stock motor. The problem with a stock turbo is the small turbine wheel, which causes backpressure. This back pressure causes the spent gases to re-enter the combustion chamber if over lap is too great.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
