Hey all,
I have had my metal 5 inch cat installed for a while now in my r32 gtst, and lately in hot weather or a long time driving my cat over-temperature light sometimes flashes.
Should I be worried? Is it important or just because of the new type of cat? (metal vs. ceramic)
Or is it a sign that my car is running lean? It does it with Optimax, BP Ultimate and Boost 98.
Cheers,
Rhett
Going by his mods
Dyno junkie - 128.3 rwkW! Mods - filter and catback.
There's no pfc. :rofl:
Just before my cat died second and third gear would occasionionally see the cat overtemp light flash. Initially I thought it was the pfc showing knock or a sensor reaching its max, it wasn't. :D
are you sure they re-installed the sensor when they put the new cat in? I've seen a few when they removed the sensor and the wiring was shorting against the car body occaisionaly which lit up the warning light. anyway the cat temp sensor is not important. it's just to tell you 1. cat is overheating and may be damaged, and 2. do not park in long grass as you may start a fire.
Well I watched the G-man put it back in when he installed the cat.
And I'm pretty sure that noone has broken into my car over the last few months and stealthily installed a power fc without me knowing about it...
So i guess apexi use it as the check light because it is the otherwise most useless light in the dash?
So i'll just ignore it. thanks.
    • Hard to say, just pop the rocker covers off and have a look if you think it's cammed. You probably need to replace the valve cover gasket/half moons anyways.
    • From my youth: GTi-R clutch change is a massive pain. The gearboxes are fragile? But the car is super cool and I want one 😢
    • Remember this is 1988 tech.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
