post-28634-1172657408.jpgMitsubishi 6A12G MIVEC V6
RPW carbongraphite decompression head gasket (approx 9.0:1)
Custom Garrett 450hp hybrid ballbearing turbocharger (T28/T04 hybrid)
Custom 2.5' mandrel-bent dump pipe
Custom stainless exhaust manifold
Custom turbo intake feed pipe
Custom stainless intercooler piping
Custom 2.5' mandrel-bent mild steel exhaust (cat-back)
Custom Genesis-tuned Microtech LTX-8S ECU
6x Bosch 480cc injectors
Walbro 500hp in-tank fuel pump
Apex'i air-pod filter
Apex'i AVCR Boost Controller
Custom front mounted air-to-air tube & fin intercooler
HKS Super Sequential Blow-off Valve
Samco silicon hoses
Braided oil lines
Modified inlet manifold
Custom oil breather tank
NGK Iridium spark plugs
Speedflow anodised hose fittings
Custom radiator and air filter heatshield (in carbonfibre)
Engine modifications worth all ($9,000)
DRIVELINE:
Factory 5-speed manual (modified with stronger internals)
Exedy Hyper single plate heavy duty clutch with lightened & balanced flywheel
Rare factory LSD
WHEELS / BRAKES / SUSPENSION:
17' BuddyClub P1 Racing lightweight Japanese alloy wheels with Bridgestone Potenza G3 tyres ($2,000)
Sheepdog Prof-Sport springs ($350)
Cusco upper strut tower brace front & rear ($500)
BODYSTYLING:
Custom aero front bumper (GPvR/DCuatro hybrid)
Genuine C-West carbonfibre front canards
Custom modified Kansai wing (ala Porsche GT2-style) ($2,000)
High-Intensity Discharge 7500K headlight conversion **SOLD**
I.C.E:
Panasonic MP3 head deck
1x Cadence Q4000 4ch amplifier
1x 12' Phoenix Gold Tantrum 12D subwoofer in sealed enclosure
Kenwood front coaxial speakers
System worth ($1,000)
INTERIOR:
EL gauges ($200)
Defi Heads Up Display ($350)
Pivot turbo timer
Razo gearknob & pedals
Sabelt harness pads
AVCR boost controller ($400)
Factory genuine Momo airbag wheel
For that enthusiust who want to be different,
Stiil has more power left in the turbo roughly another 150KW, needs internals done.
Price: $17,500
Alot of $$$ spent, true sleeper!
RWC & 12MONTHS REG.
post-28634-1172657408.jpg post-28634-1172657580.jpg post-28634-1172657687.jpg post-28634-1172657812.jpg post-28634-1172660889.jpg post-28634-1172660985.jpg post-28634-1172661119.jpg
  • 1 month later...
  • 1 month later...
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
