skyline ER34 turboengine car (HICAS) 用 16 steps of TEIN TypeHA damping force adjustment type Vehicle height tone kit it is -- !. ■ Spring rate F:7kg R:7kg ■ adjustable range F:-25?-76mm R:+11?-46mm ■ It is price \174,000 (according to tax) at the time of order PIROAPPA specification ■ sale (with TEIN documents). Trade-in car By a thing Use period Two years, ten months A run is . It was a thing with about 7,000km. * . There is neither shocking NUKE nor an oil leak. Since I am fine, it is future still more!. It turned around all. TEIN accepts necessity. It is cheap, and since OH is also made, it is the Cho ? く使えます to a change. It is HP of TEIN. Please make it * reference. (It is an end model of sales) * Skyline ER34 It is an object for the Huy CAS cars (the lower part of RIA is a character type of KO). Keep in mind that the lower part does not suit the vehicles of O by 2000cc NA etc. sure to read self-introduction before a bid! ♪ -- natural The taking over of the direction near [ which are needlessness, such as a consumption tax and a charge of a system, ] ♪ * is also a welcome. I can also introduce an attachment shop, although it is Kanagawa within the prefecture. Dispatch is 郵 pack YAMATO TRANSPORT. It enables it to send at a low price in Sakawa etc. as
This is the auction report when they were purchased, I helped HolyEvil buy these and bring them to Australia .
The seller claims they were 2 years old and travelled 7000 km .
I hope that helps you in some way .
Thanks wrxhoon! =)
bump bump... surely someone would want this set of coilovers.. DAMN if mine was turbo ..it'll be on straight away...
if ANYONE can advice me one how to change de rear coilovers from inverted fork to eye.. please msg me..
Fulcrum is asking for 400.. anyone knows a place where they can do it for cheaper? hopefully in sydney..
I really want these in my car.
cheers
yes this is correct.. only fit a GTT and not a GT-(whatever)
cheers
Actually, they will also fit a GTV which has the turbo suspension and brakes but N/A engine ( 4 door ).
( I know cause I have a GTV & they are eye @ the front & fork @ the back )
Hope that helps you move these >_< They look VERY nice !
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
