  • Replies 53
to get any noise in neutral, you need to rev the shit out of it, hard and fast! you need to make a larger mass of moving air on the intake side so that not only does your boost register, but it also squeezes through the factory bov...
but none the less, the problem your having is normal, i have a feeling that when you had the new turbo fitted, it actually fixed the problem you had with the car before without you even knowing you had a problem...
which was most likely a flow problem...
also, fix your clutch before it gets too bad...
yea i really doubt its the turbo since ive had it fitted alogn with assisting mods ive driven it about 4 time in nearly 2 months, reken upgrading the clutch should do the trick ? and ty for more helpfull comments im still young and dont know a whole lot so maybe i wrote the rong thing in the thread title..
i gota gt30 internaly gated fitted, say a week ago before wat happened i could rev it in neutral and it was fine even when normal driving i cant hit boost at all and struggles to get to like 3-4 thousand revs. im trying to think if its the clutch or maybe i have a bigger problem ..
Lack of RPM has nothing to do with the clutch.
Take it back to the workshop that fitted the turbo and get them to fix what they stuffed up.
:nyaanyaa: cheers :happy:
Actually, oops, I didn't write what I said above clearly. I agree with SK. if the clutch was slipping, the revs would rise like crazy bu the car won't move.
so if it's not allowing it to rev, it's something else
Edited by MANWHORE
i gota gt30 internaly gated fitted, say a week ago before wat happened i could rev it in neutral and it was fine im trying to think if its the clutch or maybe i have a bigger problem ..
what size rear housing is it?
"even when normal driving i cant hit boost at all and struggles to get to like 3-4 thousand revs."
sounds like it might have too large an A/r
on the gt30
or there a restriction in the intake or exhaust or cat
how was the car driving before the gt30 was fitted
as i said before and will say it again this problem has only occured after driving it a week ago on my way to a igntion cruise here in perth i gave it a bit in 2nd hit about 5 thousand rpm then dropped rappidly after that is when i cant hit boost at all in any gear neutral driving nothing,
Check your wastegate maybe.. cos its internally gated could have popped the little thingomabob off the flapper from the actuator causing the flapper to be constantly open..?
just a suggestion :O
Dear god is it school holidays or something?
Like Sydney Kid said, take your car to the mechanic that did the work.
Something is wrong. If it was the clutch slipping, the engine would be revving whilst not accellerating.
If your car is unable to rev normally and is not making boost, something is seriously wrong. Take it to your mechanic.
Edited by Mitch_Rona
r33hvn that seems likea possibility
which one? the wastegate part or the vac line part?
either way maybe you should take it to the mechanic and ask him to tell you whats wrong b4 he starts working on it... that way you can see if its going to cost you mega$$ or not.. possibly not... if the wastegate rod has fallen off the flapper its cos they didn't put that freaking little circlip on it...
if its vac line its a $20 fix maybe even less... either of the 2 its easy fiX bud!
anything else is beyond me... :O
boost no work in neutral
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AHAHHAHAHAHAAHAH
boostie no workie in nuetral buddy... Although I'm sure if this was asked on Nissansilva.com he'd get an answer more harsher than this now. So take it easy on him and lets not reduce ourselved to ns.com levels. lol.
Sammie I had the same problem. It turns out my turbo blew. It is either the wastegate staying OPEN or there is no external wheel left on the turbo lol. check for white smoke please.
EDIT: I had the same problem but my wastegate was shut the whole time. ~boost.
Edited by Pauly33GTS-t
Yes your ceramic turbo lost its wheels... :O
Not his GT30 that he fitted 4 weeks ago... and he said before that theres no smoke... so i assume it can't be that severe.. well he hopes not anyways
ok guys ur gona think im stupid as most of u do already but i had a good look and i found one of my intercooler pipes has come off.. and that would explain what happened when i drove it that night as i was goin up in revs the nall off a sudden felt like a big release of pressure and turns out my piping has come off lol ...
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
