Hey all. I just thought i might bore you all with what i did tonite. Needed to remove my engine and gear box from my 1982 subaru to replace clutch and gear box. I started the task after tea around 7pm and managed to have the gear box and motor out in only 4hrs.
Well thats what i been doing. I know some of you will be like " thats slow as man" but i think its good. Ah well just thought i would share something.
Yeah its easier to take out gearbox with the engine than to f around with separating them in the car. Plus i am changing the gear box for another one that i had sitting around cos the current one is a bit f'ed. Yeah i did the whole thing myself and with a few beers lol. yeah had to remove front cv joints, tail shaft. I have removed the engine a few times in my paddock bomb so i had bit experience on this type of vehicle. would make life easier if i had a hoist. just used car stands and an engine crane. bit slower but does the job.
from engine running to gtr box out in 1 hour by myself, thats with no hoist and only axle stands and a jack to assist :P
gtr engine running and out in around 4 hours by myself as well
done box around 20 times now and engine about 10-12 times i think so gets easier the more u do it lol :laugh:
i know what bolt sizes are on every damn part of the engine and box, its pretty disturbing :)
lol nice work guys. yeah i dont think i would be strong enough to try and take gear box out from under and put it back in. hard to manipulate it in tight spaces. yeah i knew what alot of sizes where on my car. mostly 10,12,14,17.
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
